I've downloaded Ubuntu for the first time on a old desktop because I want to learn how to use Ubuntu as I would any other OS. But the machine is Ethernet only and I don't really want to buy 20M cable or a power line adapter.
I do have a USB wireless network adapter I dug out. So I've downloaded the driver for it and I've also got 'wine-3.0.tar.xz' file onto a USB stick from a different device and put them on the desktop.
But I don't know how to install the wine file onto the system properly to then run the exe file for the driver... Any help?
I've currently tried:
sudo cp ~/desktop/wine-3.0.tar.xz* /var/cache/apt/archives/
(which worked as it should.)
Then:
sudo apt-get install wine
Which didn't work. :(
Eliah Kagan
  • 119,640
Refer procedure given on this page:
Installing without Internet
To install Wine on an Ubuntu machine without internet access, you must have access to a second Ubuntu machine (or VM) with an internet connection to download the Wine .deb package and its dependencies.
On the machine with internet, add the WineHQ repository and run apt update as described above.
Next, cache just the packages necessary for installing wine, without extracting them:
sudo apt-get clean
sudo apt-get --download-only install winehq-devel
sudo apt-get --download-only dist-upgrade
Copy all of the .deb files in /var/cache/apt/archives to a USB stick:
cp -R /var/cache/apt/archives/ /media/usb-drive/deb-pkgs/
Finally, on the machine without internet, install all of the packages from the flash drive:
cd /media/usb-drive/deb-pkgs
sudo dpkg -i *.deb
The same instructions can also be used for an offline installation of the winehq-staging packages.
Ajay
  • 688
