I am having alot of error in my dpkg and I am at my limit of fixing it. I cant install or update or remove packages. I've tried many solution but all fails and ends up at
If i upgrade from 18.04 to 20.04 will this fix my dpkg problem?
EDIT:
sample output:
martin@martin:~$ sudo apt-get install -f Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libapt-inst1.5 libapt-pkg4.12 Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up initramfs-tools (0.130ubuntu3.9) ... update-initramfs: deferring update (trigger activated) dpkg-maintscript-helper: error: dpkg: error: unknown option --validate-version Type dpkg --help for help about installing and deinstalling packages [*]; Use 'apt' or 'aptitude' for user-friendly package management; Type dpkg -Dhelp for a list of dpkg debug flag values; Type dpkg --force-help for a list of forcing options; Type dpkg-deb --help for help about manipulating *.deb files; Options marked [*] produce a lot of output - pipe it through 'less' or 'more' ! dpkg: error processing package initramfs-tools (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) martin@martin:~$
