I have Ubuntu 18.04.3. Every time I do sudo apt install gcc I get:
Reading package lists... Done
Building dependency tree
g++ : Depends: g++-7 (>= 7.3.0-12~) but it is not going to be installed
Depends: gcc-7 (>= 7.3.0-12~) but it is not going to be installed
gcc : Depends: gcc-7 (>= 7.3.0-12~) but it is not going to be installed
I have tried: install -f; it does not upgrade or remove anything. dpkg --get-selections | grep hold does not output anything. sudo aptitude install gcc gave:
The following NEW packages will be installed:
cpp{a} cpp-7{a} gcc gcc-7{a} gcc-7-base{a} libasan4{a} libatomic1{ab} libc-dev-bin{a}
libc6-dev{a} libcilkrts5{a} libgcc-7-dev{a} libisl19{a} libitm1{ab} liblsan0{ab} libmpc3{a}
libmpx2{ab} libquadmath0{ab} libtsan0{ab} libubsan0{a} linux-libc-dev{a} manpages-dev{a}
0 packages upgraded, 21 newly installed, 0 to remove and 0 not upgraded.
Need to get 24.2 MB/24.2 MB of archives. After unpacking 98.5 MB will be used.
libmpx2 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
libitm1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
libquadmath0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
libtsan0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
liblsan0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
libatomic1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04.1 is installed
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) gcc [Not Installed]
2) gcc-7 [Not Installed]
3) libatomic1 [Not Installed]
4) libgcc-7-dev [Not Installed]
5) libitm1 [Not Installed]
6) liblsan0 [Not Installed]
7) libmpx2 [Not Installed]
8) libquadmath0 [Not Installed]
9) libtsan0 [Not Installed]
Accept this solution? [Y/n/q/?] y
cpp{a} cpp-7{a} gcc-7-base{a} libisl19{a} libmpc3{a}
0 packages upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,354 kB/7,373 kB of archives. After unpacking 25.3 MB will be used.
Do you want to continue? [Y/n/?] y
Get: 1 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 libisl19 amd64 0.19-1 [551 kB]
Get: 2 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 libmpc3 amd64 1.1.0-1 [40.8 kB]
Get: 3 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 cpp-7 amd64 7.3.0-16ubuntu3 [6,734 kB]
Get: 4 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 cpp amd64 4:7.3.0-3ubuntu2 [27.5 kB]
Fetched 7,354 kB in 1s (6,081 kB/s)
Selecting previously unselected package gcc-7-base:amd64.
(Reading database ... 160059 files and directories currently installed.)
Preparing to unpack .../gcc-7-base_7.3.0-16ubuntu3_amd64.deb ...
Unpacking gcc-7-base:amd64 (7.3.0-16ubuntu3) ...
Selecting previously unselected package libisl19:amd64.
Preparing to unpack .../libisl19_0.19-1_amd64.deb ...
Unpacking libisl19:amd64 (0.19-1) ...
Selecting previously unselected package libmpc3:amd64.
Preparing to unpack .../libmpc3_1.1.0-1_amd64.deb ...
Unpacking libmpc3:amd64 (1.1.0-1) ...
Selecting previously unselected package cpp-7.
Preparing to unpack .../cpp-7_7.3.0-16ubuntu3_amd64.deb ...
Unpacking cpp-7 (7.3.0-16ubuntu3) ...
Selecting previously unselected package cpp.
Preparing to unpack .../cpp_4%3a7.3.0-3ubuntu2_amd64.deb ...
Unpacking cpp (4:7.3.0-3ubuntu2) ...
Setting up gcc-7-base:amd64 (7.3.0-16ubuntu3) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Setting up libmpc3:amd64 (1.1.0-1) ...
Setting up libisl19:amd64 (0.19-1) ...
Setting up cpp-7 (7.3.0-16ubuntu3) ...
Setting up cpp (4:7.3.0-3ubuntu2) ...
I checked for gcc -v again and still 'gcc' not found. I am at a loss, I even tried using aptitude in a more dangerous way to get gcc-base 7 and it wound up removing a lot including my firefox browser so I just killed that before it could finish. I was afraid it was deleting too much of my installation. I am not sure why this is being so difficult. Any help is greatly appreciated!
