I have a system dual boot with Windows 10 and Ubuntu 16.04. Windows 10 can access the internet, but Ubuntu 16.04 can't. I have checked in Windows 10 where WOL is not enabled on the ethernet. And you can see that the ethernet status (eno1) is up in Ubuntu 16.04.
Below are some results
$ ping 8.8.8.8
connect: Network is unreachable
From above you can see it's not domain server problem (Indeed, before that I have tried changing /etc/resolv.conf to include line nameserver 8.8.8.8 and it does not work and I found out that it's not domain server problem)
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 18:31:bf:ce:35:39 brd ff:ff:ff:ff:ff:ff 3: enp14s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
link/ether 18:31:bf:ce:35:3a brd ff:ff:ff:ff:ff:ff 5: br-e5e68b901b8d: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:bc:39:1c:1b brd ff:ff:ff:ff:ff:ff 6: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:90:09:22:e9 brd ff:ff:ff:ff:ff:ff
$ ifconfig -a
br-e5e68b901b8d Link encap:Ethernet HWaddr 02:42:bc:39:1c:1c
inet addr:172.18.0.1 Bcast:172.18.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
docker0 Link encap:Ethernet HWaddr 02:42:90:09:22:ec
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
eno1 Link encap:Ethernet HWaddr 18:31:bf:ce:35:3c
inet6 addr: fe80::fd89:7b2:8432:3e66/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:302 errors:0 dropped:0 overruns:0 frame:0
TX packets:96 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:50635 (50.6 KB) TX bytes:10704 (10.7 KB)
Interrupt:20 Memory:fb600000-fb620000
enp14s0 Link encap:Ethernet HWaddr 18:31:bf:ce:35:3c
Memory:fb300000-fb37ffff
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:37180 errors:0 dropped:0 overruns:0 frame:0
TX packets:37180 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:14199410 (14.1 MB) TX bytes:14199410 (14.1 MB)
Any comments is welcome and highly appreciated!
