trying to install unebootin on ubuntu 18.04 after install get this: sorry- newbie question, but do I answer y or n and can I install without them or are they necessary? Thanks in advance,
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  extlinux p7zip p7zip-full unetbootin-translations
Suggested packages:
  p7zip-rar
Recommended packages:
  gksu | kdesudo
The following NEW packages will be installed
  extlinux p7zip p7zip-full unetbootin unetbootin-translations
0 to upgrade, 5 to newly install, 0 to remove and 18 not to upgrade.
Need to get 2,107 kB of archives.
After this operation, 10.1 MB of additional disk space will be used.
Do you want to continue? [Y/n]
do I need these to install?
Jos
  • 30,529
  • 89
  • 96
You must install these. Packages have often other packages as dependencies. This has the advantage that packages don't need to maintain their dependencies, e.g. if a used packages gets an update, the update is installed by the package manager and the package that uses the updated package gets the advantages of the update.
