I am having problems using a VPN with the pritunl client on Ubuntu 20.04.
When using the VPN, I am able to get pings (i.e. ping 8.8.8.8 is fine), but websites are not loading. From searching online, this should be due to a DNS resolution problem.
I could not find threads specific about Ubuntu 20.04 regarding this problem, while I think this may be dependent on the Ubuntu version (for example, there seemed to be no problems before Ubuntu 16.04).
So far, my search for a solution has lead to:
- I have been told that this is due to a network-manager issue, and been recommended to downgrade to a specific version to solve this, but it does not work as it looks like the last network-manager version without the issue is not available on Ubuntu 20.04:
Commands:
$ sudo apt install network-manager=1.10.6-2ubuntu1.1
Reading package lists... Done
Building dependency tree
E: Version '1.10.6-2ubuntu1.1' for 'network-manager' was not found
- Another solution found online seems to be valid for Ubuntu 18.04:
Ubuntu 18.04 no DNS resolution when connected to openvpn
I think the second answer (answer by Qlimax, not the accepted one) looks best. Is that expected to work on Ubuntu 20.04 too? Any downside with this? I would like to have confirmation before doing anything, as I do not want to break / compromise anything on my system.
- Finally, I wonder if the post there may also be an answer to this problem:
https://docs.pritunl.com/docs/gnome-client
Then I suppose this bypasses the pritunl client altogether and uses the gnome client, right? Any downsides I should be aware of?
Finally, wondering the following: if this is well a network-manager issue, do you know if a fix is in the pipes? I can find some bug reports online but it does not seem that much is happening, which is surprising...
