OS: Ubuntu 20.04.
root@la425:~# apt-get update
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Ign:2 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu focal InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://ppa.launchpad.net/ondrej/php/ubuntu focal InRelease
Hit:8 http://archive.ubuntu.com/ubuntu focal-security InRelease
Err:9 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu focal Release
  404  Not Found [IP: 91.189.95.83 80]
Hit:3 https://downloads.mariadb.com/MariaDB/mariadb-10.4/repo/ubuntu focal InRelease
Ign:7 https://downloads.mariadb.com/MaxScale/2.4/ubuntu focal InRelease
Hit:10 https://downloads.mariadb.com/Tools/ubuntu focal InRelease
Err:11 https://downloads.mariadb.com/MaxScale/2.4/ubuntu focal Release
  404  Not Found [IP: 104.20.67.208 443]
Reading package lists... Done
N: Ignoring file 'mariadb.list.old_1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'mariadb.list.old_2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: The repository 'http://ppa.launchpad.net/chris-lea/redis-server/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://downloads.mariadb.com/MaxScale/2.4/ubuntu focal Release' does not have a Release file.
Based on the output of the apt process, it seems you added manually some other unofficial repositories, which is okay. But when doing so you have to make sure they support you OS flavor, or at least the dists exist. You can't just add focal and hope it'll work.
When browsing manually to https://downloads.mariadb.com/MaxScale/2.4/ubuntu, there is no dist named focal, and this explains the 404 Not Found error. Same goes for http://ppa.launchpad.net/chris-lea/redis-server/ubuntu.
The error N: Ignoring file 'mariadb.list.old_1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension speaks a little bit by itself, and should be fixed. You can read more about managing your sources and repo lists here: Repositories/Ubuntu
Pizza
  • 1,512
