I need libpangox-1.0-0:i386 to build a package under Ubuntu 20.04LTS, but it is not currently available.
I have libpangox-1.0-0 in my system.
The 32 bit version is available for 19.10 and below at https://pkgs.org/download/libpangox-1.0-0 https://ubuntu.pkgs.org/19.10/ubuntu-universe-i386/libpangox-1.0-0_0.0.2-5build1_i386.deb.html
What are alternative ways to obtain this?
If I get the
.debfile for 19.10 and runsudo gdebi libpangox-1.0-0_0.0.2-5build1_i386.deb, does it simply store files listed under "Files" in the web page, without any further changes to the system other than registering the package fordpkg?Can I give it a shot, try if it works, and if not simply remove the package? (there might be some issues, since files under
/usr/share/doc/libpangox-1.0-0, even if only documentation, are shared among 32 bit and 64 bit versions). Note that the files in the package are only thesoand a soft link to it,/usr/lib/i386-linux-gnu/libpangox-1.0.so.0and/usr/lib/i386-linux-gnu/libpangox-1.0.so.0.0.0.
Notes: I never built something like this from source.
EDIT:
To avoid messing with dpkg, as a first attempt I expanded the .deb file, and copied the so and soft link by hand into /usr/lib/i386-linux-gnu.
Then
$ export LD_LIBRARY_PATH="/usr/lib/i386-linux-gnu"
$ fakeroot debian/rules binary
dpkg-shlibdeps: error: no dependency information found for /usr/lib/i386-linux-gnu/libpangox-1.0.so.0 (used by debian/iscan/usr/bin/iscan)
Hint: check if the library actually comes from a package.
which led me to trying three workarounds at the same time:
- Adding to
debian/rules
override_dh_shlibdeps:
(tab) dh_shlibdeps --dpkg-shlibdeps-params=--ignore-missing-info
$ export DEB_DH_SHLIBDEPS_ARGS_ALL=--dpkg-shlibdeps-params=--ignore-missing-info$ export DEB_BUILD_OPTIONS=nocheck
None of this removed the error above.
EDIT #2.
Trying to build the library, I got the error
$ debuild -a i386
dpkg-deb: building package 'libpangox-1.0-dev' in '../libpangox-1.0-dev_0.0.2-5ubuntu1_i386.deb'.
dpkg-genbuildinfo
dpkg-genchanges >../pangox-compat_0.0.2-5ubuntu1_i386.changes
dpkg-genchanges: info: not including original source code in upload
dpkg-source --after-build .
dpkg-source: info: using options from pangox-compat-0.0.2/debian/source/options: --compression=xz
dpkg-buildpackage: info: binary and diff upload (original source NOT included)
debuild: fatal error at line 1062:
can't open pangox-compat_0.0.2-5ubuntu1_amd64.changes for reading: No such file or directory
Related:
https://linux.debian.user.narkive.com/tVuR0mKc/package-shared-library-with-application
https://github.com/SpiderLabs/ModSecurity-nginx/issues/16
https://www.man7.org/linux/man-pages/man1/dpkg-shlibdeps.1.html
https://ubuntu.com/blog/statement-on-32-bit-i386-packages-for-ubuntu-19-10-and-20-04-lts
