I have an issue with the wifi in a HP 15-db0598sa that I've installed lubuntu 20.04 on.
Pinging google.com gives typical output of the form:
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=171 ttl=53 time=12.3 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=172 ttl=53 time=96.4 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=175 ttl=53 time=1026 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=176 ttl=53 time=11.2 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=177 ttl=53 time=11.4 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=178 ttl=53 time=10.3 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=179 ttl=53 time=10.5 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=181 ttl=53 time=1035 ms
64 bytes from lhr25s26-in-f14.1e100.net (172.217.169.14): icmp_seq=182 ttl=53 time=22.9 ms
where the ping varies from ~10ms (as on my other machines) up to > 1000 ms, with the odd ping (about 24% packet loss) dropped (such as between 172 and 175 and 179 and 181 above).
The output of lspci -knn | grep Net -A3 is as follows:
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723DE 802.11b/g/n PCIe Adapter [10ec:d723]
        DeviceName: WLAN
        Subsystem: Hewlett-Packard Company RTL8723DE 802.11b/g/n PCIe Adapter [103c:8319]
        Kernel driver in use: rtw_pci
I have disabled IPv6 on the dhcp as in this answer: https://askubuntu.com/a/1180403/489692
In furtherance to DESGUA's answer, I changed /etc/dhcp/dhclient.conf. More specifically, I deleted line 18:
dhcp6.name-servers, dhcp6.domain-search, dhcp6.fqdn, dhcp6.sntp-servers,
I eventually disconnected wifi and reconnected.
and that ameliorated some issues, but the ping is still intermittently ~10ms and >1000ms.
Are there any other configuration settings I could use to improve the stability of the connection (besides using wired networking - this laptop will be in a different room to the router so this is possible, but I'd prefer to use the wireless).
To add: I've got an older machine using Ubuntu 18.04 in the same location, and the ping there is fine:
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=4 ttl=53 time=12.8 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=5 ttl=53 time=11.6 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=6 ttl=53 time=12.1 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=7 ttl=53 time=11.0 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=8 ttl=53 time=11.0 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=9 ttl=53 time=21.8 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=10 ttl=53 time=11.3 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=11 ttl=53 time=11.5 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=12 ttl=53 time=12.3 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=13 ttl=53 time=13.2 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=14 ttl=53 time=11.6 ms
64 bytes from ams16s21-in-f14.1e100.net (216.58.212.206): icmp_seq=15 ttl=53 time=11.5 ms
EDIT: I have tried installing the driver here (for RTL8723DE) https://github.com/lwfinger/rtlwifi_new/tree/extended and the output of lspci -knn | grep Net -A3 remains:
        DeviceName: WLAN
so it looks like the new drive hasn't installed. I'm at a complete loss now
user36196
  • 544
I think the fix for the internal wifi is to
sudo apt install git dkms
git clone https://github.com/lwfinger/rtlwifi_new.git
cd rtlwifi_new/
git checkout extended
git checkout 0a751e3
cd
sudo dkms add rtlwifi_new
sudo dkms install rtlwifi-new/0.6
echo "options rtl8723de ant_sel=2" | sudo tee /etc/modprobe.d/rtl8723de.conf
echo "blacklist rtw_pci" | sudo tee /etc/modprobe.d/rtw_pci.conf
Reboot
Jeremy31
  • 13,293
