I'm using OBS Studio and would like to have a virtual video output saved permanently so that it can be run when the application is launched.
This command creates the virtual output:
sudo modprobe v4l2loopback video_nr=10 card_label="OBS Video Source" exclusive_caps=1
But I must run the command in console on each boot. How can I make this permanent? The plugin that utilizes the output in OBS Studio is configured to auto start but /dev/video10 is not available after a reboot of the system.
$ modinfo v4l2loopback | grep -i parm
parm:           debug:debugging level (higher values == more verbose) (int)
parm:           max_buffers:how many buffers should be allocated (int)
parm:           max_openers:how many users can open loopback device (int)
parm:           devices:how many devices should be created (int)
parm:           video_nr:video device numbers (-1=auto, 0=/dev/video0, etc.) (array of int)
parm:           card_label:card labels for every device (array of charp)
parm:           exclusive_caps:whether to announce OUTPUT/CAPTURE capabilities exclusively or not (array of bool)
parm:           max_width:maximum frame width (int)
parm:           max_height:maximum frame height (int)
Eliah Kagan
  • 119,640
Mark Lee
  • 277
Normally kernel modules can be added to /etc/modules for loading at boot time.
Add this to /etc/modules...
However, I don't know if you can pass parameters there. So here's another way to do it.
v4l2loopback
Create /etc/modprobe.d/v4l2loopback.conf
options v4l2loopback video_nr=10 card_label="OBS Video Source" exclusive_caps=1
Then...
sudo update-initramfs -c -k $(uname -r)
reboot
Confirm module loading with...
lsmod | grep -i v4l2loopback
heynnema
  • 73,649
Easy way to do it un Ubuntu 20.04 and others:
$ sudo echo "v4l2loopback" > /etc/modules-load.d/v4l2loopback.conf
$ sudo echo "options v4l2loopback video_nr=10 card_label=\"OBS Video Source\" exclusive_caps=1" > /etc/modprobe.d/v4l2loopback.conf
You can restart to check it works!
NOTICE
Be aware of a bug on v4l2loopback-dkms 0.12.3-1ubuntu0.1
More info on this stackoverflow post.
EDIT - Using tee
As pointed by renyhp, it's better to use the tee command:
$ sudo echo "v4l2loopback" | tee /etc/modules-load.d/v4l2loopback.conf
$ sudo echo "options v4l2loopback video_nr=10 card_label=\"OBS Video Source\" exclusive_caps=1" | tee /etc/modprobe.d/v4l2loopback.conf
EDIT - Update modules
As commented, it seems that in some systems after rebooting some problems can be experienced. To avoid that, it's always a good idea to update the modules:
PabloRQ
  • 199
