I'm trying to implement X11VNC on Ubuntu 20.04 but it's been frustrating. I need to use command way, the goal is to keep it on a systemd service.
As I know Ubuntu is using Xorg for the moment. Running ps wwwwaux | grep auth I get this:
gdm 3530 0.0 2.4 211180 50128 tty1 Sl+ 10:41 0:01 /usr/lib/xorg/Xorg vt1 -displayfd 3 -auth /run/user/125/gdm/Xauthority -background none -noreset -keeptty -verbose 3
admin-r+ 4700 0.2 2.7 216112 55220 tty2 Sl+ 11:58 0:02 /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -background none -noreset -keeptty -verbose 3
So it should be correct to run the X11VNC server like this when user is not logged in (forget security pls):
x11vnc -xkb -noxrecord -noxfixes -noxdamage -forever -rfbport 11226 -auth /run/user/125/gdm/Xauthority -display :0
And like this when it's logged in:
x11vnc -xkb -noxrecord -noxfixes -noxdamage -forever -rfbport 11226 -auth /run/user/1000/gdm/Xauthority -display :0
Well, it works good on GDM, but not when the user is logged in.
  • Tried with root and user profile of course.
  • UUIDs checked of course.
Also tried with the directive GDM conf file WaylandEnable=false commented and without comment. When comment it, it works running this when the user is logged in:
x11vnc -xkb -noxrecord -noxfixes -noxdamage -forever -rfbport 11226 -display :0
But not works in GDM. If I comment it, it works on GDM from root with:
So I don't get a solution for everything. I'm now out of ideas. LightDM is not a solution, cause we want to use GDM3.
Any response will be highly appreciated.
Regards.
The problem was the display. As lightdm only uses one display (:0), GDM raises a display for each user, so this should be correct and works for me:
x11vnc -xkb -noxrecord -noxfixes -noxdamage -forever -rfbport 11226 -auth /run/user/1000/gdm/Xauthority -display :1
-1
I've had similar problems. I couldn't login to Ubuntu on the boot screen. and finally came up with a workaround script to fix X11VNC's issues while using the default GDM3 on Ubuntu 21. I wish X11VNC would fix this.
Use this as a setup script to configure your X11VNC after installing x11vnc.
    #!/bin/bash
if [ -z "$1" ]; then echo "Please pass the password you would like to use as an argument to this script"; exit 1 ; else echo "Good start.going ahead."; fi
apt update && apt install tmux -y password=$1 passwordfile='/etc/x11vnc.pass' servicefile='/etc/systemd/system/x11vnc.service' timerfile='/etc/systemd/system/x11vnc.timer' script='/usr/bin/startxvnc' apt-get update apt-get install x11vnc net-tools -y x11vnc -storepasswd $password $passwordfile
cat >$servicefile <<'EOT' [Unit] Description="x11vnc" Requires=display-manager.service
[Service] Type=simple #Environment=XAUTHORITY=$(ps aux | grep -o -E "(-auth)(.)(Xauth)[a-zA-Z]+") #ExecStart=tmux new -s gj -d '/usr/bin/x11vnc $(ps aux | grep -o -E "(-auth)(.)(Xauth)[a-zA-Z]+") -display :0 -rfbauth /etc/x11vnc.pass -shared -forever' #ExecStartPre=tmux new -s x11vnc -d ExecStart=bash -c /usr/bin/startxvnc #ExecStop=tmux kill-session -t x11vnc Restart=on-failure RestartSec=2
[Install] WantedBy=graphical.target WantedBy=multi-user.target
EOT
cat >$timerfile <<'EOT' Unit] Description=Wait for some time before running X11VNC
[Timer] OnBootSec=5sec
[Install] WantedBy=timers.target
EOT
cat >$script <<'EOT' #!/bin/bash
getxauths() { xauths=()
ps aux | grep -o -E "(-auth)(.*)(Xauth)[a-zA-Z]+" | (while IFS= read -r xauth do xauths+=("$xauth") done printf "%s\n" "${xauths[@]}" | sort -u ) }
getpname() { #psp=$(ps -p $(lsof -t -i:5900) -o command) psp=$(cat /proc/$(lsof -t -i:$1)/cmdline) echo $psp }
killproc() { pkill -9 $(lsof -t -i:$1) echo "Killed by port $1" }
starttmux() { xauth=$1 tmux new -s $xauth -d tmux send-keys -t $xauth:0 "for (( ; ; )) ; do sleep 3s; ((disp ^= 1)) ; /usr/bin/x11vnc -display :$disp -auth $xauth -rfbauth /etc/x11vnc.pass -shared -forever ; done" Enter
#echo $(getpname) start() { for (( ; ; )) ; do
#echo $psp xauths=$(getxauths) for xauth in $xauths ; do xauth="$xauth" | xargs if [[ ${xauth} != "-auth" ]];then unset tsessions tsessions=($(tmux list-sessions -F '#{session_name}'))
echo "tessions is " ${tsessions[@]}
echo "xauth is " ${xauth} if [[ ! " ${tsessions[@]} " =~ " ${xauth} " ]]; then starttmux $xauth
psp=$(getpname 5900) echo $psp | grep -E -o "(-auth)(.)(Xauth)[a-zA-Z]+" | (while IFS= read -r xold do sessionname=$(echo ${xold#"-auth"} | xargs) #tmux kill-session -t "$sessionname" if [[ ! " ${tsessions[@]} " =~ " ${xauth} " ]]; then if [[ $psp == "user/125"* ]] ; then killproc 5900 ; tmux kill-session -t "$sessionname" ; echo "session name is $sessionname" ; fi ; else starttmux $xauth ; sleep 30s ; fi done)
    fi
fi
done
sleep 3s done } start EOT
chmod u+x $script sed -i -e 's/WaylandEnable=true/WaylandEnable=false/g' /etc/gdm3/custom.conf sed -i -e 's/#WaylandEnable=false/WaylandEnable=false/g' /etc/gdm3/custom.conf
systemctl daemon-reload systemctl enable x11vnc.timer systemctl stop x11vnc.service systemctl disable x11vnc.service systemctl restart x11vnc.timer
Josh
  • 241
