14
I am getting GEGL version too old error whlie opening GIMP after updating to Ubuntu 20.04. The complete error is
GEGL version too old!
GIMP requires GEGL version 0.4.22 or later. Installed GEGL version is 0.4.18.
Somehow you or your software packager managed to install GIMP with an older GEGL version.
Please upgrade to GEGL version 0.4.22 or later.
But I checked my installed gegl version which is 0.4.22-3.
GEGL image
I have done described here but it does not work
Please help !!! I am not able to use GIMP.
Here is /etc/apt/sources.list file
# deb cdrom:[Ubuntu 19.10 _Eoan Ermine_ - Release amd64 (20191017)]/ eoan main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://in.archive.ubuntu.com/ubuntu/ focal main restricted universe
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://in.archive.ubuntu.com/ubuntu/ focal-updates main restricted universe
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan universe
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan multiverse
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://in.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe
deb-src http://in.archive.ubuntu.com/ubuntu/ eoan-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu eoan partner
deb-src http://archive.canonical.com/ubuntu eoan partner
deb http://security.ubuntu.com/ubuntu focal-security main restricted universe
deb-src http://security.ubuntu.com/ubuntu eoan-security main restricted
deb-src http://security.ubuntu.com/ubuntu eoan-security universe
deb-src http://security.ubuntu.com/ubuntu eoan-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
xaif
  • 241
7 Answers7
17
I had the same problem on Ubuntu Mate 20.04.
Resolved it as follows. The otto-kesselgulasch repository is depreciated and is no longer maintained. It needs to be replaced.
sudo apt install ppa-purge
sudo ppa-purge ppa:otto-kesselgulasch/gimp
sudo add-apt-repository ppa:ubuntuhandbook1/gimp
sudo apt update && sudo apt upgrade
If that doesn't work you may need to re-install GIMP
sudo apt install gimp gimp-gmic
This worked for me.
You may also need to do
sudo apt autoremove
and
for a number of cycles until all the dependencies are satisfied and unused dependencies removed.
Trying to install GEGL didn't help for me. I removed / purged GIMP (and GEGL 0.4.22 - it was installed correctly!) as above a number of times without result. However, doing this routine from the start worked first-time on my second machine!
Thanks to Ubuntu Handbook for hosting the repository.
jhoran
  • 171
11
I had the same problem. You can solve it by removing gimp with
sudo apt remove --auto-remove gimp
This also removes the leftover dependencies of the gimp packages, and hence all the versions of libgegl and older dependencies.
and then reinstall gimp by
This will install the latest versions of the required dependencies for gimp.
Pablo Bianchi
  • 17,371
sudo apt purge gimp
sudo apt purge libgegl-0.4-0
worked for me.
Kulfy
  • 18,154
I had the same issue, solved by removing Otto PPA:
sudo apt install ppa-purge -y
It will tell you that some packages need a downgrade, accept et voila'
(I was coming from 19.10 upgraded to 20.04)
d.lime
  • 160
I have upgraded from Kubuntu 18.04 LTS to 20.04 LTS. For me, none of the above solutions worked, couldn't start gimp because of gegl error.
I searched for gegl version still installed:
$ sudo apt list | grep gegl
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
gegl/focal,now 0.4.22-3 amd64 [installiert] gir1.2-gegl-0.4/focal 0.4.22-3 amd64 libgegl-0.4-0/now 1:0.4.18+om-0ubu18.04.18~ppa amd64 [Installiert,lokal] libgegl-common/now 1:0.4.18+om-0ubu18.04.18~ppa all [Installiert,lokal] libgegl-dev/focal 0.4.22-3 amd64 libgegl-doc/focal,focal 0.4.22-3 all
The I removed the old gegl version:
$ sudo apt-get remove libgegl-0.4-0
After that, gimp starts again :-)
hwv
You can just try:
sudo apt-get install gegl
Eliah Kagan
  • 119,640
-1
Con esto me ha funcionado a mi.
sudo apt install ppa-purge && sudo ppa-purge ppa:otto-kesselgulasch/gimp
sudo apt-get install gimp
Saludos,
