I am rumming 20.04 having upgraded from 19.10. On boot up my Gnome-Log list the following four important warnings:
Hardware: pcieport 0000:00:1d.6: AER: [12] Timeout
Other: gkr-pam: unable to locate daemon control file
Hardware: iwlwifi 0000:02:00.0: BIOS contains WGDS but no WRDS
System: Initramfs unpacking failed: Decoding failed
Does anyone know how to fix one or all of these warnings
Edit: Result of sudo grep -i AER /var/log/syslog*
/var/log/syslog.1:May 27 09:38:25 kernel: [ 2112.333692] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 09:38:25 kernel: [ 2112.333717] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 09:38:25 kernel: [ 2112.333729] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 09:38:25 kernel: [ 2112.333737] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 09:45:41 kernel: [ 2548.495211] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 09:45:41 kernel: [ 2548.495232] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 09:45:41 kernel: [ 2548.495241] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 09:45:41 kernel: [ 2548.495246] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 10:00:17 kernel: [ 3424.914424] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 10:00:17 kernel: [ 3424.914447] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 10:00:17 kernel: [ 3424.914456] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 10:00:17 kernel: [ 3424.914461] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 10:32:38 kernel: [ 5365.540516] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 10:32:38 kernel: [ 5365.540538] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 10:32:38 kernel: [ 5365.540545] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 10:32:38 kernel: [ 5365.540550] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 10:35:10 kernel: [ 5517.598490] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 10:35:10 kernel: [ 5517.598511] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 10:35:10 kernel: [ 5517.598518] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 10:35:10 kernel: [ 5517.598523] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 11:08:03 kernel: [ 7490.357204] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 11:08:03 kernel: [ 7490.357222] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 11:08:03 kernel: [ 7490.357227] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 11:08:03 kernel: [ 7490.357230] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 11:55:48 kernel: [10355.729066] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 11:55:48 kernel: [10355.729091] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 11:55:48 kernel: [10355.729100] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 11:55:48 kernel: [10355.729107] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 12:02:08 kernel: [10735.692104] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 12:02:08 kernel: [10735.692128] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 12:02:08 kernel: [10735.692138] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 12:02:08 kernel: [10735.692145] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 12:04:08 kernel: [10856.011819] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 12:04:08 kernel: [10856.011840] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 12:04:08 kernel: [10856.011846] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 12:04:08 kernel: [10856.011851] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 12:18:08 kernel: [11695.963571] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 12:18:08 kernel: [11695.963592] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 12:18:08 kernel: [11695.963599] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 12:18:08 kernel: [11695.963604] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 12:55:33 kernel: [13940.856114] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 12:55:33 kernel: [13940.856133] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 12:55:33 kernel: [13940.856144] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 12:55:33 kernel: [13940.856152] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 13:09:14 kernel: [14761.290891] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 13:09:14 kernel: [14761.290912] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 13:09:14 kernel: [14761.290919] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 13:09:14 kernel: [14761.290924] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 13:22:54 kernel: [15581.750396] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 13:22:54 kernel: [15581.750419] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 13:22:54 kernel: [15581.750428] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 13:22:54 kernel: [15581.750436] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 14:01:07 kernel: [17874.670685] pcieport 0000:00:1d.6: AER: Multiple Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 14:01:07 kernel: [17874.670752] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 14:01:07 kernel: [17874.670759] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 14:01:07 kernel: [17874.670763] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 15:05:53 kernel: [ 0.302749] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 27 15:05:53 kernel: [ 1.246204] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 27 15:05:53 kernel: [ 1.246689] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 27 15:05:53 kernel: [ 1.247155] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 27 15:52:35 kernel: [ 2807.311812] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 15:52:35 kernel: [ 2807.311826] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 15:52:35 kernel: [ 2807.311828] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 15:52:35 kernel: [ 2807.311829] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 16:19:59 kernel: [ 4451.886604] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 16:19:59 kernel: [ 4451.886624] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 16:19:59 kernel: [ 4451.886632] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 16:19:59 kernel: [ 4451.886637] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 16:28:57 kernel: [ 4990.073432] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 16:28:57 kernel: [ 4990.073454] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 16:28:57 kernel: [ 4990.073462] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 16:28:57 kernel: [ 4990.073468] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 16:47:22 kernel: [ 6094.485311] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 16:47:22 kernel: [ 6094.485335] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 16:47:22 kernel: [ 6094.485344] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 16:47:22 kernel: [ 6094.485351] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 17:12:59 kernel: [ 7631.201166] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 17:12:59 kernel: [ 7631.201187] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 17:12:59 kernel: [ 7631.201194] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 17:12:59 kernel: [ 7631.201199] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 18:25:24 kernel: [11976.939762] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 18:25:24 kernel: [11976.939786] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 18:25:24 kernel: [11976.939797] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 18:25:24 kernel: [11976.939804] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 18:30:59 kernel: [12311.582585] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 18:30:59 kernel: [12311.582605] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 18:30:59 kernel: [12311.582615] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 18:30:59 kernel: [12311.582622] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 18:32:59 kernel: [12431.466043] pcieport 0000:00:1d.6: AER: Multiple Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 18:32:59 kernel: [12431.466062] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 18:32:59 kernel: [12431.466070] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 18:32:59 kernel: [12431.466076] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 18:33:56 kernel: [12489.130439] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 18:33:56 kernel: [12489.130461] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 18:33:56 kernel: [12489.130469] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 18:33:56 kernel: [12489.130474] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 19:18:49 kernel: [15182.096585] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 19:18:49 kernel: [15182.096609] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 19:18:49 kernel: [15182.096621] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 19:18:49 kernel: [15182.096630] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 19:33:58 kernel: [16090.404395] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 19:33:58 kernel: [16090.404415] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 19:33:58 kernel: [16090.404425] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 19:33:58 kernel: [16090.404432] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 19:41:00 kernel: [16512.597276] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 19:41:00 kernel: [16512.597293] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 19:41:00 kernel: [16512.597296] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 19:41:00 kernel: [16512.597299] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 20:32:43 kernel: [19616.044249] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 20:32:43 kernel: [19616.044264] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 20:32:43 kernel: [19616.044267] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 20:32:43 kernel: [19616.044270] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 20:41:03 kernel: [20116.212322] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 20:41:03 kernel: [20116.212338] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 20:41:03 kernel: [20116.212343] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 20:41:03 kernel: [20116.212381] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 20:48:16 kernel: [20548.388744] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 20:48:16 kernel: [20548.388767] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 20:48:16 kernel: [20548.388776] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 20:48:16 kernel: [20548.388782] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 21:38:03 kernel: [23535.317470] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 21:38:03 kernel: [23535.317491] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 21:38:03 kernel: [23535.317499] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 21:38:03 kernel: [23535.317504] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 21:45:37 kernel: [23989.480880] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 21:45:37 kernel: [23989.480901] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 21:45:37 kernel: [23989.480910] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 21:45:37 kernel: [23989.480915] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 22:01:09 kernel: [24921.815861] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 22:01:09 kernel: [24921.815882] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 22:01:09 kernel: [24921.815889] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 22:01:09 kernel: [24921.815894] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 22:02:25 kernel: [24997.844261] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 22:02:25 kernel: [24997.844281] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 22:02:25 kernel: [24997.844290] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 22:02:25 kernel: [24997.844298] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 22:07:45 kernel: [25317.969850] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 22:07:45 kernel: [25317.969870] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 22:07:45 kernel: [25317.969877] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 22:07:45 kernel: [25317.969883] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 27 22:18:53 kernel: [25986.200037] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 27 22:18:53 kernel: [25986.200076] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 27 22:18:53 kernel: [25986.200084] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 27 22:18:53 kernel: [25986.200090] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 08:34:00 kernel: [ 0.301707] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 08:34:00 kernel: [ 1.225656] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 08:34:00 kernel: [ 1.226112] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 08:34:00 kernel: [ 1.226549] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 09:18:53 kernel: [ 2697.157606] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 09:18:53 kernel: [ 2697.157627] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 09:18:53 kernel: [ 2697.157634] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 09:18:53 kernel: [ 2697.157640] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 09:21:21 kernel: [ 2845.220042] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 09:21:21 kernel: [ 2845.220062] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 09:21:21 kernel: [ 2845.220069] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 09:21:21 kernel: [ 2845.220074] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 09:26:57 kernel: [ 3181.350293] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 09:26:57 kernel: [ 3181.350311] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 09:26:57 kernel: [ 3181.350319] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 09:26:57 kernel: [ 3181.350325] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 09:29:37 kernel: [ 3341.414226] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 09:29:37 kernel: [ 3341.414246] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 09:29:37 kernel: [ 3341.414253] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 09:29:37 kernel: [ 3341.414258] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 12:05:10 kernel: [ 0.303700] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 12:05:10 kernel: [ 1.250362] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 12:05:10 kernel: [ 1.250826] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 12:05:10 kernel: [ 1.251276] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 12:31:14 kernel: [ 1569.476749] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 12:31:14 kernel: [ 1569.476771] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 12:31:14 kernel: [ 1569.476778] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 12:31:14 kernel: [ 1569.476784] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 13:29:22 kernel: [ 5056.862044] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 13:29:22 kernel: [ 5056.862065] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 13:29:22 kernel: [ 5056.862072] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 13:29:22 kernel: [ 5056.862077] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 17:33:55 kernel: [ 0.302831] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 17:33:55 kernel: [ 1.246804] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 17:33:55 kernel: [ 1.247281] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 17:33:55 kernel: [ 1.247748] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 18:32:33 kernel: [ 0.298382] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 18:32:33 kernel: [ 1.221683] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 18:32:33 kernel: [ 1.222139] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 18:32:33 kernel: [ 1.222573] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 20:28:42 kernel: [ 0.304403] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 20:28:42 kernel: [ 1.249976] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 20:28:42 kernel: [ 1.250430] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 20:28:42 kernel: [ 1.250863] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 20:37:31 kernel: [ 0.302937] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
/var/log/syslog.1:May 28 20:37:31 kernel: [ 1.225075] pcieport 0000:00:1d.0: AER: enabled with IRQ 122
/var/log/syslog.1:May 28 20:37:31 kernel: [ 1.225527] pcieport 0000:00:1d.5: AER: enabled with IRQ 123
/var/log/syslog.1:May 28 20:37:31 kernel: [ 1.225960] pcieport 0000:00:1d.6: AER: enabled with IRQ 124
/var/log/syslog.1:May 28 20:40:42 kernel: [ 196.724856] pcieport 0000:00:1d.6: AER: Corrected error received: 0000:00:1d.6
/var/log/syslog.1:May 28 20:40:42 kernel: [ 196.724876] pcieport 0000:00:1d.6: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
/var/log/syslog.1:May 28 20:40:42 kernel: [ 196.724889] pcieport 0000:00:1d.6: AER: device [8086:a336] error status/mask=00001000/00002000
/var/log/syslog.1:May 28 20:40:42 kernel: [ 196.724897] pcieport 0000:00:1d.6: AER: [12] Timeout
/var/log/syslog.1:May 28 22:55:00 dbus-daemon[7748]: [session uid=0 pid=7746] Activating service name='org.a11y.Bus' requested by ':1.1' (uid=0 pid=7742 comm="gedit AER /var/log/syslog /var/log/syslog.1 /var/l" label="unconfined")
/var/log/syslog.1:May 28 22:55:00 dbus-daemon[7748]: [session uid=0 pid=7746] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.0' (uid=0 pid=7742 comm="gedit AER /var/log/syslog /var/log/syslog.1 /var/l" label="unconfined")
Übereinstimmungen in Binärdatei /var/log/syslog.3.gz
Übereinstimmungen in Binärdatei /var/log/syslog.5.gz
Übereinstimmungen in Binärdatei /var/log/syslog.6.gz
