-1
I get the below error when I try to install also i am not getting the below mentioned dependencies
$ rpm -i sgdclient-5.40.941-1.el7.x86_64.rpm
rpm: RPM should not be used directly install RPM packages, use Alien instead!
rpm: However assuming you know what you are doing...
error: Failed dependencies:
    /bin/sh is needed by sgdclient-5.40.941-1.el7.x86_64
    desktop-file-utils is needed by sgdclient-5.40.941-1.el7.x86_64
    libX11.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXcursor.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXext.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXfixes.so.3()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXinerama.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXm.so.4()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXpm.so.4()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libXt.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libc.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libc.so.6(GLIBC_2.14)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libc.so.6(GLIBC_2.2.5)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libc.so.6(GLIBC_2.3)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libc.so.6(GLIBC_2.7)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libcurl.so.4()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libdl.so.2()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libdl.so.2(GLIBC_2.2.5)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libgcc_s.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libgcc_s.so.1(GCC_3.0)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libm.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libpthread.so.0()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libpthread.so.0(GLIBC_2.2.5)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libpthread.so.0(GLIBC_2.3.2)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    librt.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6(CXXABI_1.3)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6(CXXABI_1.3.1)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6(GLIBCXX_3.4)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6(GLIBCXX_3.4.14)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libstdc++.so.6(GLIBCXX_3.4.15)(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libxkbfile.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    libz.so.1()(64bit) is needed by sgdclient-5.40.941-1.el7.x86_64
    rtld(GNU_HASH) is needed by sgdclient-5.40.941-1.el7.x86_64
It seems that The Oracle has only released an rpm package for SGD Client as well as the server. Remember in order to install a program manually in a debian-based linux distribution you should have a .deb package first .
So in this case you have to either convert the rpm package to deb one using Alien or to install and use that software in an RedHat-based distribution.
I prefer the latter because it's usually (if not always) easier to install an rpm package on RedHat-based distros like Fedora just because the dependencies of them are easier to install from such a repository (vs ubuntu's ).
But in the case you just want to create a server , you can install a Fedora on VirtualBox or VMWare . There's no need to install another linux distro next to the one you currently have.
