I am running Ubuntu 18.04 and I have an old .deb file that I'm trying to install. The Ubuntu Software app failed to install it, so I did sudo dpkg -i headoverheels_1.0.1-1_amd64.deb
This resulted in:
dpkg: dependency problems prevent configuration of headoverheels:
   headoverheels depends on liballegro4.2 (>= 2:4.2.2); however:
   Package liballegro4.2 is not installed.
   headoverheels depends on libxerces-c28; however:
   Package libxerces-c28 is not installed.
But liballegro4.2 does appear to be available, so I tried sudo apt-get install liballegro4.2-dev. However -
Note, selecting 'liballegro4-dev' instead of 'liballegro4.2-dev'
The following additional packages will be installed:
  liballegro4.4 libjpgalleg4.4
The following NEW packages will be installed
  liballegro4-dev liballegro4.4 libjpgalleg4.4
Older versions of liballegro are available from https://pkgs.org/download/liballegro4.2-dev but the oldest (for Ubuntu 14.04) is also version 4.4.
What is the best approach here?
The original deb file was marked as 'for Ubuntu 10.04' so can I obtain the deb files for liballegro4.2 and libxerces-c28 from the Lucid repository somehow? (I'd prefer to have the deb files to keep, so I can install this program again in the future on a different machine)
This question deals with installing older packages that are listed on packages.ubuntu.com, but that only goes as far back as 14.04.
Carl H
  • 6,316
  • 28
  • 42
To install binary version you need to get many dependencies manually:
cd ~/Downloads
wget http://archive.ubuntu.com/ubuntu/pool/main/i/icu/libicu52_52.1-3_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/universe/x/xerces-c2/libxerces-c28_2.8.0+deb1-3build1_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/universe/a/allegro4.2/liballegro4.2_4.2.2-3_amd64.deb
sudo apt-get install ./libicu52_52.1-3_amd64.deb
sudo apt-get install ./libxerces-c28_2.8.0+deb1-3build1_amd64.deb
sudo apt-get install ./liballegro4.2_4.2.2-3_amd64.deb
and then install the game:
wget http://www.headoverheels2.com/descargas/headoverheels_1.0.1-1_amd64.deb
sudo apt-get install ./headoverheels_1.0.1-1_amd64.deb
Launch it with headoverheels command.
N0rbert
  • 103,263
