I'm trying to boot a USB with Windows-10 and making it bootable from Linux (Ubuntu).
For this purpose, I installed Woe-USB as a snap package. The USB drive is formatted to exfat.
I get this weird error:
sudo woe-usb.woeusb --device ~/Desktop/Win10_2004_EnglishInternational_x64.iso /dev/sdb
WoeUSB v@@WOEUSB_VERSION@@
/snap/woe-usb/21/bin/woeusb: line 918: /bin/mount: Permission denied
/snap/woe-usb/21/bin/woeusb: line 899: /bin/mount: Permission denied
Mounting source filesystem...
mkdir: cannot create directory '/media/woeusb_source_1590608570_38263': Permission denied
mount_source_filesystem: Error: Unable to create "/media/woeusb_source_1590608570_38263" mountpoint directory
/snap/woe-usb/21/bin/woeusb: line 1302: /bin/mount: Permission denied
mount_source_filesystem: Error: Unable to mount source media
Error: Unable to mount source filesystem
You may now safely detach the target device
Any ideas?
Benny
  • 5,100
You got a /bin/mount: Permission denied mount_source_filesystem: Error: Unable to mount source media Error: Unable to mount source filesystem error. Connect the woe-usb:removable-media plug to the woe-usb:removable-media slot in order to enable USB devices to be mounted automatically by WoeUSB.
  1. Search for woeusb in Ubuntu Software and click it to go to the woe-usb screen.
  2. Click the Permissions button.
  3. Toggle the Read/Write files on removeable storage devices slider from OFF to ON as shown in the below screenshot.
  4. Authenticate with your user password when the Authentication Required window pops up.
woe-usb Permissions
karel
  • 122,292
  • 133
  • 301
  • 332
Install
Fix Permissions
It is happening because WoeUSB running under /snap "partition", to fix this, just copy it to a different location, for example:
sudo cp -v /snap/woe-usb/21/bin/woeusb /usr/bin/
Usage
sudo /usr/bin/woeusb --device PATHTO.iso /dev/sdb --target-filesystem NTFS
Note: Make sure to change PATHTO.iso to the desired image, and /dev/sdb to the correct USB device (you can use sudo blkid to see your devices), and NTFS, otherwise, see the supported list.
Benny
  • 5,100
