I have developed a brightness indicator for unity in python. I change the brightness using the following system call:
echo 4 > /sys/class/backlight/acpi_video0/brightness  [value = 0 to 9]
Problem is this command needs root access. Because of brightness file's permission:
-rw-r--r-- 1 root root 4096 2012-04-23 17:36 /sys/class/backlight/acpi_video0/brightness
So i just change the file's permission to 775. It worked. But after reboot the file's permission change again. Now it can not be done because permission denied. How can i do this without root permission?
thanks in advance
shantanu
  • 8,835
One thing you can do is change the permissions in some sort of startup script, such as /etc/rc.local.
Ibrahim
  • 158
