I am new to Ubuntu and I installed the Ubuntu 11.10 on my system. I want to share a folder on my local network. How can I do that?
I want to share a folder by right click on it. when I do this then it say to install the samba and when I try to install the samba then it show some files not found on ubuntu server.
On installation process time I got the error lik
root@sys:~# sudo apt-get install samba
Reading package lists...
Done
Building dependency tree
Reading state information...
Done
The following extra packages will be installed:
libwbclient0 samba-common smbclient
Suggested packages:  openbsd-inetd inet-superserver smbldap-tools ldb-tools cifs-utils
The following NEW packages will be installed:  samba
The following packages will be upgraded: libwbclient0 samba-common smbclient
3 upgraded, 1 newly installed, 0 to remove and 372 not upgraded.
Need to get 23.3 MB of archives.
After this operation, 23.0 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
 libwbclient0 smbclient samba-common samba
Install these packages without verification [y/N]? y
Err http://np.archive.ubuntu.com/ubuntu/ oneiric-updates/main libwbclient0 i386 2:3.5.11~dfsg-1ubuntu2.1  404  Not Found
Err http://np.archive.ubuntu.com/ubuntu/ oneiric-updates/main smbclient i386 2:3.5.11~dfsg-1ubuntu2.1  Bad header line
Err http://np.archive.ubuntu.com/ubuntu/ oneiric-updates/main samba-common all 2:3.5.11~dfsg-1ubuntu2.1  404  Not Found
Err http://np.archive.ubuntu.com/ubuntu/ oneiric-updates/main samba i386 2:3.5.11~dfsg-1ubuntu2.1  404  Not Found
Failed to fetch http://np.archive.ubuntu.com/ubuntu/pool/main/s/samba/libwbclient0_3.5.11~dfsg-1ubuntu2.1_i386.deb  404  Not Found
Failed to fetch http://np.archive.ubuntu.com/ubuntu/pool/main/s/samba/smbclient_3.5.11~dfsg-1ubuntu2.1_i386.deb  Bad header line
Failed to fetch http://np.archive.ubuntu.com/ubuntu/pool/main/s/samba/samba-common_3.5.11~dfsg-1ubuntu2.1_all.deb  404  Not Found
Failed to fetch http://np.archive.ubuntu.com/ubuntu/pool/main/s/samba/samba_3.5.11~dfsg-1ubuntu2.1_i386.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Since the right click isn't working for you, open a Terminal window and enter the following command:
sudo apt-get install samba smbfs
That should install the software you need. Then retry the right click and share option.
Phil Hannent
  • 1,595
  • Open software center and install samba from there. See the picture below.
samba
  • After installation launch samba. You will see a window like below. Click on + icon to add a new share. enter image description here
  • Alternatively right click on a folder and choose sharing options
Web-E
  • 21,716
The easiest way are using UbuntuOne. Right-click and share any folder with any one in the world.
Another easy way, and very secure are using SSH and "File/Connect to server" in Nautilus your file handler. On the machine that has the folder you want to share you have to install openssh-server from Ubuntu program center (its listed as an technical object).
The latter method uses strong enchryption and you can use the same technique shareing the folder over Internet.
This is a simple article you can follow:
http://www.liberiangeek.net/2011/11/a-quick-way-to-share-folders-in-ubuntu-11-10-oneiric-ocelot/
aneeshep
  • 30,949
