I am trying to get SocketCAN interface working. I've added the slcan0 adapter and trying to run candump slcan0 at a bit rate I am sure the CAN devices is running at. I dont see any data being printed in the terminal while I am sure CAN device is sending data at 200Hz.
I am using Lawicel CANUSB device and following these steps: http://pascal-walter.blogspot.com/2015/08/installing-lawicel-canusb-on-linux.html
When i am printing system log after binding the interface, I get following information:
May 26 10:11:33 username gnome-software[3664]: Failed to load snap icon: local snap has no icon
May 26 10:11:34 username gnome-software[3664]: message repeated 4 times: [ Failed to load snap icon: local snap has no icon]
May 26 10:15:43 username systemd[1]: Started Session 3 of user aceinna.
May 26 10:15:57 username slcand[3923]: starting on TTY device /dev/ttyUSB0
May 26 10:15:57 username slcand[3923]: attached TTY /dev/ttyUSB0 to netdevice slcan0
May 26 10:15:57 username slcand[3923]: netdevice O#015 renamed to slcan0
May 26 10:15:57 username NetworkManager[1543]: <info> [1590513357.4839] manager: (slcan0): new Generic device (/org/freedesktop/NetworkManager/Devices/4)
May 26 10:15:57 username systemd-udevd[3925]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
May 26 10:15:57 username NetworkManager[1543]: <info> [1590513357.4957] devices added (path: /sys/devices/virtual/net/slcan0, iface: slcan0)
May 26 10:15:57 username NetworkManager[1543]: <info> [1590513357.4958] device added (path: /sys/devices/virtual/net/slcan0, iface: slcan0): no ifupdown configuration found.
May 26 10:16:23 username wpa_supplicant[1539]: wlp59s0: WPA: Group rekeying completed with bc:ee:7b:57:ed:fc [GTK=CCMP]
May 26 10:17:01 username CRON[3944]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
The problem is, "no ifupdown configuration found"
How do I configure ifupdown configuration for CAN interface?
One of the thing i tried was adding following lines to /etc/network/interfaces
auto can0
iface can0 inet manual
#pre-up ip link set $IFACE type can bitrate 125000 listen-only off
pre-up /sbin/ip link set $IFACE type can bitrate 250000 triple-sampling on
up /sbin/ifconfig $IFACE up
down /sbin/ifconfig $IFACE down
Note: I tried using can0 as adapter name when binding the interface to match with interface name in /etc/network/interfaces.
I also updated ifupdown package using
apt-get ifupdown
Can some one point out to right direction, what should I be looking at?
Thanks in advance.
