Terminals has buffers which might reside on disk even without ecryption ( I don't know about gnome-terminal but I'm using Konsole and if you set the scrollback to unlimited then it buffers its contents unencrypted somewhere in the /tmp)
And another problem might be your bash_history. Each command that you type ( the exception is when you add a space before your command ) will go to your ~/.bash_history file if you close the terminal properly (i.e not in the event of a system crash ).
So if you want to type your sensitive information like passwords in a console command , you have to either delete that line manually or add a space before your command ( I didn't see it anywhere , but I found it myself with trial and error and might not work for other shells other than bash . For example that's not the case in the Z shell. And also might someday get removed from bash. Who knows)
In the ~/.bashrc file there are two variables as follows
HISTSIZE=2000
HISTFILESIZE=2000
If you set them to a negative number like -1 , then the bash history size would be unlimited . And if you want to disable the bash history feature , you can set them to zero. ( note that the bash history is an useful feature in the case you forgot the commands (i.e syntax or arguments) that you issued. For example I had a bash_history with the age of almost one year ! with almost 60,000 lines !)
Note that if in your terminal you've logged in as another user like root then the bash_history will go to /root/.bash_history not in your home directory.
And if you want to reboot or halt your system via terminal ( when you're working on the server , logged in via console , or just for fun ) then you should issue the command :
history -c && some_halt_command
to prevent the history buffer to be flushed into the bash_history.(although if you disable the feature via the aforementioned variables , I don't think you would need this)
So :
1) Delete that line manually from history
2) Add a space before your command if you use bash (which is default in most (if not all) distros)
3) Disable bash history
