I want to write batch or something, that will write output of top into a file on login.
I did top >> output-file, but it contains some strange character!
Can somebody give a simple tutorial about how to write batch file in Linux?
Try the following
top -b -n1 > filename.txt
The -b is for batch mode, which should prevent the strange characters. The -n1 tells it to only print one iteration.
Go to terminal and type:
user@ubuntu:~$ top > filename.txt
The output of top command will be now stored in a text file which is located in your Home directory.
See: Bash scripting Tutorial.
