This is a new install on a Sony Vaio E-series VPCEB11FM.
After pressing the power button to boot, if I then hit Esc or Shift to open the GRUB menu, and then selected the first (default) menu option labelled "Ubuntu", the system boots to the desktop perfectly.
However, if I don't open GRUB and just the install boot after powering on, Ubuntu won't boot:...
the purple screen will display for a short-while
then
the 5-dots loading screen will display, but will flash with every change of the dot
and then hang forever on this flashing 5-dot display
unless
I type some magical combo of Ctrl-Alt-F2 , 3, 4, etc...
and then a tty login screen will appear
then, over the tty screen, the mouse cursor will appear after a moment or two, which generally indicates that the GUI login screen is now ready.
Simplified version: Ubuntu doesn't want to boot to the GUI unless it first displays something in "ANSI", either GRUB or a tty screen.
Ugh?
As described in the question, something about the splash screen and/or loading screen was bothering the gdm.
So I used this ...
https://askubuntu.com/a/198605/1087176
... and disabled the splash screen, as well as disabled 'quiet' so that the boot process would always display progress via text-mode output.
Boots properly now... or at least properly enough.
