Ubuntu 20.04 on Hyper-V VM
I am trying to do something similar to what is written in this answer. I think this answer logs all the terminal to a certain file. I would like to be able to log all my terminal input/output by day if possible. So then when I want to know what I did on any particular day, I can go to that days log file and read the input/output of my terminal.
Adam Ch
  • 183
I don't know if you can install software on the server machine, but ZSH an FISH, alternatives to BASH shell, have timestamps store on their history files per command ran. In ZSH is stored per row and FISH use two rows per command. Both use Unix Time Stamp. zsh : 1591635588:0;ssh user@server ls /tmp fish 989 - cmd: ssh user@server ls /tmp 990 when: 1591387835
I use ZSH, with oh-my-zsh installed, instead of bash. ZSH's history file (~/.zsh_history) keep each command (row)stored as bash but puts at the beginning the Linux Time Stamp of the moment that command was ran. To keep the history at your side, client side, you can run the command via ssh:
$~> ssh user@server ls /tmp
$~> ssh user@server cat /etc/os-release
On ZSH it is store like so:
$~> cat ~/.zsh_history
: 1591636831:0;ssh user@server cat /etc/os-release
If you run AWK against the file you can translate the timestamps:
$~> awk -F":" '{print strftime("%Y-%m-%d %H\:%M\:%S", $2),$3}' ~/.zsh_history
2020-06-08 14:49:10 0;ssh user@server ls /tmp
2020-06-08 14:50:04 0;ssh user@server cat /etc/os-release
You can filter by date using together with grep, for example, and send it to a file:
$~> awk -F":" '{print strftime("%Y-%m-%d %H:%M:%S", $2),$3}' ~/.zsh_history \
| grep -E "2020-06-08" > ${HOME}/2020-06-08-history.log
msmafra
  • 195
