Backstory: I installed Ubuntu 20.04 on my Laptop. My additional monitor was not working and Nvidia drivers were also not working. Settings > About was showing Integerated Intel card. Tried installing but nvida-smi and nvidia-settings were not able to detect the driver giving messages like nvidia driver not loaded.
What I tried: Did lot of random stuff to finally install Nvidia 440 driver from the runfile installation. This random stuff included adding nouveau blacklist, nvidia purge, install from runfile, change boot mode from UEFI to something else. Now the driver is working fine, it shows up in Settings > About, nvidia-settings and nvidia-smi work fine.
The issue: Now it is not detecting my main laptop monitor while the external works fine. If I go to Settigs > Displays, I only see the external monitor, not my main one. Display is coming up only on external and there is black screen on main one. In nvidia-settings I see only one monitor in Layout. Also, if I disconnect the external display, it does not boot, stays stuck at loading screen.
Beg for help: What did I do wrong? What can I attempt to solve this?
Output of xrandr -q:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440    144.00*+ 120.00    59.95    59.95
   1920x1080    119.88    60.00    59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94
DP-1 disconnected (normal left inverted right x axis y axis)
Output of lspci -vv:
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
    DeviceName: Onboard - Other
    Subsystem: Micro-Star International Co., Ltd. [MSI] 8th Gen Core Processor Host Bridge/DRAM Registers
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
    Latency: 0
    Capabilities: <access denied>
    Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07) (prog-if 00 [Normal decode])
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 122
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 00004000-00004fff [size=4K]
    Memory behind bridge: a4000000-a50fffff [size=17M]
    Prefetchable memory behind bridge: 0000000090000000-00000000a20fffff [size=289M]
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
    BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
        PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Mobile) (prog-if 00 [VGA controller])
    DeviceName: Onboard - Video
    Subsystem: Micro-Star International Co., Ltd. [MSI] UHD Graphics 630 (Mobile)
    Interrupt: pin A routed to IRQ 157
    Region 0: Memory at a3000000 (64-bit, non-prefetchable) [size=16M]
    Region 2: Memory at 80000000 (64-bit, prefetchable) [size=256M]
    Region 4: I/O ports at 5000 [size=64]
    Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
    Kernel driver in use: i915
    Kernel modules: i915
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH Thermal Controller
    Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Interrupt: pin A routed to IRQ 16
    Region 0: Memory at a5423000 (64-bit, non-prefetchable) [size=4K]
    Kernel driver in use: intel_pch_thermal
    Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI])
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH USB 3.1 xHCI Host Controller
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 125
    Region 0: Memory at a5400000 (64-bit, non-prefetchable) [size=64K]
    Kernel driver in use: xhci_hcd
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
    Subsystem: Intel Corporation Cannon Lake PCH Shared SRAM
    Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Region 0: Memory at a541a000 (64-bit, non-prefetchable) [disabled] [size=8K]
    Region 2: Memory at a5422000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
    DeviceName: Onboard - Ethernet
    Subsystem: Intel Corporation Wireless-AC 9560 [Jefferson Peak]
    Region 0: Memory at a5414000 (64-bit, non-prefetchable) [size=16K]
    Kernel driver in use: iwlwifi
    Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH Serial IO I2C Controller
    Region 0: Memory at a2100000 (64-bit, non-prefetchable) [virtual] [size=4K]
    Kernel driver in use: intel-lpss
    Kernel modules: intel_lpss_pci
00:15.2 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #2 (rev 10)
    Interrupt: pin C routed to IRQ 18
    Region 0: Memory at a2101000 (64-bit, non-prefetchable) [virtual] [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH HECI Controller
    Latency: 0
    Interrupt: pin A routed to IRQ 142
    Region 0: Memory at a541f000 (64-bit, non-prefetchable) [size=4K]
    Kernel driver in use: mei_me
    Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0])
    DeviceName: Onboard - SATA
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake Mobile PCH SATA AHCI Controller
    Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 128
    Region 0: Memory at a5418000 (32-bit, non-prefetchable) [size=8K]
    Region 1: Memory at a541e000 (32-bit, non-prefetchable) [size=256]
    Region 2: I/O ports at 5090 [size=8]
    Region 3: I/O ports at 5080 [size=4]
    Region 4: I/O ports at 5060 [size=32]
    Region 5: Memory at a541d000 (32-bit, non-prefetchable) [size=2K]
    Kernel driver in use: ahci
    Kernel modules: ahci
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
    Interrupt: pin A routed to IRQ 123
    Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
    I/O behind bridge: [disabled]
    Memory behind bridge: a5300000-a53fffff [size=1M]
    Prefetchable memory behind bridge: [disabled]
00:1d.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #15 (rev f0) (prog-if 00 [Normal decode])
    Interrupt: pin C routed to IRQ 124
    Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
    I/O behind bridge: 00003000-00003fff [size=4K]
    Memory behind bridge: a5200000-a52fffff [size=1M]
00:1f.0 ISA bridge: Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Device 1272
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
    DeviceName: Onboard - Sound
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH cAVS
    Latency: 32, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 159
    Region 0: Memory at a5410000 (64-bit, non-prefetchable) [size=16K]
    Region 4: Memory at a5100000 (64-bit, non-prefetchable) [size=1M]
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel, snd_sof_pci
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH SMBus Controller
    Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Region 0: Memory at a541c000 (64-bit, non-prefetchable) [size=256]
    Region 4: I/O ports at efa0 [size=32]
    Kernel driver in use: i801_smbus
    Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH SPI Controller
    Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Region 0: Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1) (prog-if 00 [VGA controller])
    Subsystem: Micro-Star International Co., Ltd. [MSI] TU106M [GeForce RTX 2060 Mobile]
    Latency: 0
    Interrupt: pin A routed to IRQ 165
    Region 0: Memory at a4000000 (32-bit, non-prefetchable) [size=16M]
    Region 1: Memory at 90000000 (64-bit, prefetchable) [size=256M]
    Region 3: Memory at a0000000 (64-bit, prefetchable) [size=32M]
    Region 5: I/O ports at 4000 [size=128]
    Expansion ROM at a5000000 [virtual] [disabled] [size=512K]
    Kernel driver in use: nvidia
    Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
    Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 High Definition Audio Controller
    Interrupt: pin B routed to IRQ 17
    Region 0: Memory at a5080000 (32-bit, non-prefetchable) [size=16K]
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1) (prog-if 30 [XHCI])
    Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 USB 3.1 Host Controller
    Interrupt: pin C routed to IRQ 126
    Region 0: Memory at a2000000 (64-bit, prefetchable) [size=256K]
    Region 3: Memory at a2040000 (64-bit, prefetchable) [size=64K]
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
    Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 USB Type-C UCSI Controller
    Interrupt: pin D routed to IRQ 127
    Region 0: Memory at a5084000 (32-bit, non-prefetchable) [size=4K]
    Kernel driver in use: nvidia-gpu
    Kernel modules: i2c_nvidia_gpu
02:00.0 Non-Volatile memory controller: Sandisk Corp WD Black 2018/PC SN520 NVMe SSD (rev 01) (prog-if 02 [NVM Express])
    Subsystem: Sandisk Corp WD Black 2018/PC SN520 NVMe SSD
    NUMA node: 0
    Region 0: Memory at a5300000 (64-bit, non-prefetchable) [size=16K]
    Kernel driver in use: nvme
    Kernel modules: nvme
03:00.0 Ethernet controller: Qualcomm Atheros Killer E2400 Gigabit Ethernet Controller (rev 10)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Killer E2400 Gigabit Ethernet Controller
    Interrupt: pin A routed to IRQ 18
    Region 0: Memory at a5200000 (64-bit, non-prefetchable) [size=256K]
    Region 2: I/O ports at 3000 [size=128]
    Kernel driver in use: alx
    Kernel modules: alx
I'm still not convinced you did the right thing. First of all your hardware is pretty cool!.
If you install the NVIDIA drivers on a laptop with two graphics cards,make sure, that only one exists. Some laptops (like the thinkpad) have an option in the bios to enable only one of those cards. It may be that your intel drivers are not "blacklisted" in the directory /etc/modconf.d.
When I install a NVIDIA graphics card, I'm using the Hardware App provided by ubuntu: "Software& Update". There is a tab called "Additional Drivers" Select the NVIDIA-driver recommended. The process takes care of the modconf.d data.
My recommendation (I assume you used an external nvidia driver, because you wrote):
...install Nvidia 440 driver from the runfile installation
  • Remove the driver you've installed with that "runfile" installation
  • Reboot
  • If possible set the dedicated nvidia card in your bios
  • Install the drivers via the Ubuntu "Additional drivers" app
Tell us if it worked
kanehekili
  • 7,426
The thing that worked fir me was, In NVIDIA server application, i selected prime profile to intel built in GPU & rebooted.
