I have just installed Ubuntu 20.04 on my old PC. I have tried to install GIMP, but without any success. I used
$ add-apt-repository ppa:otto-kesselgulasch/gimp
The process ran for a while, but I got a number of errors and part of the output was
"The repository “cdrom://Ubuntu 20.04 LTS Focal Fossa - Release amd64 (20200 423) focal release” does not have a release file".
N: "Updating from such a repository can’t be done securely, and is therefore disabled by default". .
E: The repository http://ppa.launchpad.net/gnomebaker/stable/ubuntu focal release does not have a release file.
If anyone has any suggestions, I should be very grateful.
N0rbert
  • 103,263
Qubus
1) There is a problem with the PPA (which used to be very trustable...), it hasn't been updated since Gimp 2.10.14 last fall (current version is 2.10.18), so it doesn't support 20.04 yet.
2) The official solution (from Gimp development) to get the latest Gimp on Ubuntu is to use a flatpak version.
3) IIRC the Gimp that you get with apt install in 20.04 is a "snap" package.
4) There are also 'AppImage' versions of Gimp.
If you intent to use a rather plain Gimp, snap, flatpak and appimage will do the job, but they have restrictions: for instance the 'snap' version can only edit files under your home directory, while the flatpak version has its own "recent files" list, so you cannot easily upload a file your just edited, or edit a file you just downloaded. Adding compiled plugins that have their own dependencies may also prove difficult.
The better solution is to compile your own, which isn't that difficult, it is documented here. These instructions aren't 100% foolproof (there are some missing dependencies, quite easy to spot). Depending on the GIT branch/tag you use, you have the current 2.10.18, the fixes to be applied toward 2.10.20 (as 2.10 branch), or the future Gimp 3.0 WIP (as the master branch).
xenoid
  • 5,759
