I installed Lubuntu 18.04 on a Thinkpad T400 with P800 CPU, which is a 64-bit Processor, according to this Website. Now I can't update to 20.04 and can't install 64 bit Applications like anaconda. My System is i686.
Could it be, that i just installed the wrong version of Lubuntu?
What can I do to update to the latest version?
CBlom
  • 51
Assuming that a user has a compatible CPU, updating, or rather upgrading, from Lubuntu 18.04 to 20.04 is not recommended. The reasons are set out in the release notes for Lubuntu 20.04:
Note, due to the extensive changes required for the shift in desktop environments, the Lubuntu team does not support upgrading from 18.04 or below to any greater release. Doing so will result in a broken system. If you are on 18.04 or below and would like to upgrade, please do a fresh install.
The extensive changes mentioned above relate to the switch in desktop environments from LXDE to LXQt. (Lubuntu 18.04 was the last LXDE version).
In comments to the question, the issue of the appropriate homepage for Lubuntu came up. The current official site is https://lubuntu.me/. For a bit of background, one could read this reddit thread in which the Lubuntu Release Manager responds to questions on a variety of issues.
DK Bose
  • 44,553
For those stuck in the same situ, this is largely what I did:
  1. Switch to another desktop (see https://askubuntu.com/a/65865/44711 which is essentially steps 1-4), e.g.
sudo apt-get install xubuntu-desktop^
  1. Log out of Lubuntu and log in to the Xubuntu interface.
  2. Remove all the Lubuntu stuff, i.e.
sudo apt-get remove lubuntu-desktop
  1. Check for dangling things like lxde-, lx, etc. associated with Lubuntu and remove through apt.
  2. Then upgrade to Xubuntu 20.04 through whatever methodology you like (see https://askubuntu.com/a/1236097/44711 which is essentially steps 5 & 6). e.g.
sudo do-release-upgrade -d
  1. Restart and enjoy Xubuntu 20.04. This is where I stopped, happily.
  2. If you're set on using Lubuntu 20.04, which has the new LXQt desktop, add the Lubuntu desktop. Again, warning, I did not do this step.
sudo apt-get install lubuntu-desktop
  1. Log out and log in to the new Lubuntu interface.
YMMV.
Klimaat
  • 111
