I'd like to mount a folder on another partition (/dev/sda) named /usr to my local /usr, but I failed.
Here's my attempt:
  1. Use a live CD and select try ubuntu.
  2. Mount the partition using sudo mount -s /dev/sda /d
  3. sudo mkdir /d/usr, and copy the content to it using rsync -avH usr /d/usr
  4. remove the original /usr folder rm -rf usr
  5. add this line to etc/fstab:
UUID=74e1363e-5493-4522-977f-c267751e9d1a /d ext4 defaults 0 2
in which the 74e.... is the uuid of the partition
  1. add a symlink using sudo ln -s /d/usr .
  2. restart the computer.
this doesn't work for me and the computer can't start normally.
how can I solve this and mount a folder to /usr correctly?
ygy
  • 151
Copy everything in your /d/usr folder at the root of your /d partition if it's possible.
Then, instead of using a symlink, you can directly specify the /usr folder as the target mount folder in your fstab:
UUID=74e1363e-5493-4522-977f-c267751e9d1a /usr              ext4    defaults        0       2
You can refer to why can't /usr be a symbolic link on how to mount a folder in an already mounted partition.
Musinux
  • 156
Surprisingly, you can mount bind folders in fstab using
/olddir /newdir none bind
this is a reference to the manpages.
thanks for musinux for telling me about binding.
ygy
  • 151
