I am currently able to use my powerbeats pro as headphones with Ubuntu 20.04. However, I would like to use my headphones as a headset in certain situations.
However, the microphone on my headphones doesn't get recognized by the computer and instead uses the built-in microphone on the laptop.
I try switching audio profiles from A2DP to HFP/HSP using blueman but whenever I do it says "failed to change profile to headset_head_unit". Also when I use pulseaudio volume control and I try to switch the profile to HFP/HSP it says it is "unavailable".
Geralt
  • 169
There is a bug report on this you can subscribe to and add your voice to the chorus:
168 people are affected by or interested in this bug. Adding your input to the problem will help get it solved sooner rather than later.
After a while I just went with following with this post to enable hfp/hsp bluetooth profile on the headset. However for some reason I can't change the volume when on hfp/hsp profile but I guess that's a different issue.
Geralt
  • 169
