74
I just installed a new Ubuntu 20.04 server as a virtual machine on an esx-Server. When I look into systemlog I see lots of multipath entries.
multipathd[651]: sda: add missing path
multipathd[651]: sda: failed to get udev uid: Invalid argument
multipathd[651]: sda: failed to get sysfs uid: Invalid argument
multipathd[651]: sda: failed to get sgio uid: No such file or directory
I think multipath is just not configured and my question is if I can disable multipath. Since I checked this on several Ubuntu 20.04 servers multipath is enabled by default.
Does it make sense to activate multipath?
8 Answers8
62
Through this, I have resolved my issue:
  1. Run vi /etc/multipath.conf and add this to the file:
    defaults {
        user_friendly_names yes
    blacklist { device { vendor "VMware" product "Virtual disk" } }
  2. Restart the multipath-tools service:
    sudo systemctl restart multipath-tools
gerardw
  • 521
Sulaiman
  • 721
45
There is a SUSE linux KB on the topic - https://www.suse.com/support/kb/doc/?id=000016951. The problem is that VMWare by default doesn't provide information needed by udev to generate /dev/disk/by-id entries. Apart from ESX, VMWare Workstation (my case) is also affected. The resolution is to put
disk.EnableUUID = "TRUE"
to the virtual machine definition, i.e. into the *.vmx file or via Edit Settings -> Options tab -> General -> Configuration Parameters in ESX UI.
After rebooting VM with this parameter set, the disk are visible in /dev/disk/by-id and multipathd doesn't complain anymore.
30
If you dont have access to your host ESX you can add the following lines to your /etc/multipath.conf file which also blacklists common other devices like CDRom drives etc.
defaults {
blacklist {
    devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st|sda)[0-9]*"
Kibo
  • 751
Adding the below into the guest vm parameters worked for me. The syslog is no longer complaining and the server appears to be staying up.
This is added to the virtual machine definition, i.e. into the *.vmx file, or via Edit Settings -> Options tab -> General -> Configuration Parameters in ESX UI.
Ubuntu 20.04 running apache and Wordpress php-7.4-fpm
If you don't need multipath, turn it off:
systemctl disable multipathd
systemctl stop multipathd
Kim
  • 41
I'd use a:
defaults {
blacklist {
    devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
    devnode "^sd[a-z]?[0-9]*"
for sda, sdb, etc.
Here is another way to set it.
Use govc
Setup GOVC_URL first like
export GOVC_URL='https://username:password@vcenter.company.com/sdk'
and set UUID like
govc vm.change -e="disk.EnableUUID=TRUE" -vm='MY_VM_NAME'
One more thing, you have to poweroff and poweron to take effect this change
govc vm.power -off -force VM1
govc vm.power -on -force VM1
maxisam
  • 111
-1
Add these line in /etc/multipath.conf. this works for me all error are gone
blacklist {
        devnode "sda"
muru
  • 207,228
