I have a ryzen cpu and my cpu has been freezing/crashing a lot over the years and I couldnt' find a solution until recently and I'm told setting the max_cstate should solve my issue.
But how do I check if I set processor.max_cstate correctly from the terminal/tilix?
Current cpu: AMD Ryzen 3 1200 Quad-Core Processor
OS: Ubuntu Desktop 20.04
exts
  • 141
You can check the number of idle states your system currently supports by examination. Example 1 (limitation in place):
~$ grep . /sys/devices/system/cpu/cpu0/cpuidle/state*/name
/sys/devices/system/cpu/cpu0/cpuidle/state0/name:POLL
/sys/devices/system/cpu/cpu0/cpuidle/state1/name:C1
Example 2 (same computer, no limitation):
/sys/devices/system/cpu/cpu0/cpuidle/state2/name:C1E
/sys/devices/system/cpu/cpu0/cpuidle/state3/name:C3
/sys/devices/system/cpu/cpu0/cpuidle/state4/name:C6
/sys/devices/system/cpu/cpu0/cpuidle/state5/name:C7s
/sys/devices/system/cpu/cpu0/cpuidle/state6/name:C8
/sys/devices/system/cpu/cpu0/cpuidle/state7/name:C9
/sys/devices/system/cpu/cpu0/cpuidle/state8/name:C10
Just make the cpu number a wildcard if you want the list for everything (typically the same for each CPU).
Doug Smythies
  • 16,146
