My computer is a Lenovo ideapad 700 and I've both Windows 10 (already installed with the laptop) and Ubuntu 14 installed as dual-boot with no problem. I'm trying to install Ubuntu 18.04.4 on an external disk (WD Elements) and I've read/watched some tutorials on how to do it but my computer never boots from it. The tutorials I followed suggested dong it in Legacy mode. So I've changed the BIOS settings to use Legacy Support and Legacy First options. I also turned off secure boot and fast startup.
I used UUI to create a bootable USB flash drive and it could boot successfully. I chose Try Ubuntu and then installed Ubuntu on my external disk. I have made 3 partitions for BIOS boot, swap area and /
my disk partition table
I shut down and unplug the boot USB flash disk, then turn on. It only loads the GRUB menu for the already installed ubuntu and Windows on my machine. When I manually force it to boot from the external disk, it loads Windows
I have tried different things and I browsed the various questions, but I can't figure out where the problem is. So, any guidance is really appreciated
PS: Is my understanding correct that I only need that BIOS Boot partition (located i the first 100 GB) and no need for an EPS partition? Also, it's fine to have it as GPT?
EDIT: I want to avoid removing my internal hard disk
Hassan
