I recently installed Ubuntu 20.04 (fresh install) and installed hplip version 3.20.5 to connect my printer. Upon running hp-setup (gui) finds my printer and to click next but I run into an error below:
Searching... (bus=usb, search=(None), desc=0)
error: Unable to communicate with device (code=12): hpfax:/usb/OfficeJet_Pro_6970?serial=TH83O1P0WG
error: Unable to communicate with the device. Please check the device and try again.
Traceback (most recent call last):
  File "/usr/share/hplip/ui5/setupdialog.py", line 1104, in readwriteFaxInformation
    d.open()
  File "/usr/share/hplip/base/device.py", line 1185, in open
    raise Error(ERROR_DEVICE_NOT_FOUND)
base.g.Error: ('Device not found', 2)
During handling of the above exception, another exception occurred:
  File "/usr/share/hplip/ui5/setupdialog.py", line 1305, in NextButton_clicked
    self.showAddPrinterPage()
  File "/usr/share/hplip/ui5/setupdialog.py", line 729, in showAddPrinterPage
    self.readwriteFaxInformation()
  File "/usr/share/hplip/ui5/setupdialog.py", line 1108, in readwriteFaxInformation
    if QMessageBox.critical(self,
TypeError: critical(QWidget, str, str, buttons: Union[QMessageBox.StandardButtons, QMessageBox.StandardButton] = QMessageBox.Ok, defaultButton: QMessageBox.StandardButton = QMessageBox.NoButton): argument 5 has unexpected type 'StandardButtons'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 130, in apport_excepthook
    with open(pr_filename, 'rb') as f:
PermissionError: [Errno 13] Permission denied: '/var/crash/_usr_share_hplip_setup.py.1000.crash'
Original exception was:
    d.open()
When I run hp-check i get the following:
OfficeJet_Pro_6970_TH83O1P0WG_
Type: Unknown
Device URI: implicitclass://OfficeJet_Pro_6970_TH83O1P0WG_/
PPD: /etc/cups/ppd/OfficeJet_Pro_6970_TH83O1P0WG_.ppd
warning: Failed to read /etc/cups/ppd/OfficeJet_Pro_6970_TH83O1P0WG_.ppd ppd file
PPD Description:
Printer status: printer OfficeJet_Pro_6970_TH83O1P0WG_ is idle.  enabled since Thu 21 May 2020 08:04:45 AM PDT
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
I enabled permissions for the ppd file but still same problem. Any thoughts would be appreciated.
UPDATE:
So fully fresh install again, I wiped out all traces of previous versions of hplip and everything worked fine on installation. Unfortunately upon using the gui, although it finds the device, when I hit next, terminal spits this out below. The gui does nothing and the next button turns into an Add Printer button although the printer is still listed above.
    d.open()
    d.open()
Jeremy
  • 41
About canberra - use
sudo apt-get install libcanberra-gtk-module libcanberra-gtk-module:i386
sudo apt-get install libcanberra-gtk3-module libcanberra-gtk3-module:i386
About HPLIP - use Uninstallation part of other answer and install hplip-gui package. I do not see any removal notices about OfficeJet Pro 6970 in the releases notes, so it simply should work.
N0rbert
  • 103,263
