-1
I want to deny all outgoing traffic except to a specific address/address range. I attempted:
$ ufw default deny outgoing
$ ufw allow from x.x.x.x to any
$ ufw allow to x.x.x.x from any
However, access to x.x.x.x is denied.
Jab
Firstly, you need to check that you're actually using ufw as a firewall component - perform the following:
root@loopback:/home/mn# ufw status
Status: inactive
(Note: This requires root. I strongly recommend using sudo as opposed to root)
The alternative (as you'll see, for me ufw is inactive) is to see if you're running firewalld -sudo firewall-cmd --state should return a value:
root@loopback:/home/mn# firewall-cmd --state
running
Now,if you're running ufw you can check your rules to see what you have added:
sudo ufw show added       # Show user added rules
more /etc/ufw/user.rules  # Show system rules
To deny all outbound traffic on ufw you would perform the following:
sudo ufw default deny outgoing
Then you set your allow hosts.
