I ran updates and upgrades today and couldn't get WireGuard up:
$ sudo wg-quick up wg0
[#] ip link add wg0 type wireguard
Error: Unknown device type.
Unable to access interface: Protocol not supported
Purging and reinstalling WireGuard results in:
Setting up wireguard-dkms (1.0.20200429-2~18.04) ...
Loading new wireguard-1.0.20200429 DKMS files...
Building for 5.3.0-53-generic
Building initial module for 5.3.0-53-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/wireguard-dkms.0.crash'
Error! Bad return status for module build on kernel: 5.3.0-53-generic (x86_64)
Consult /var/lib/dkms/wireguard/1.0.20200429/build/make.log for more information.
Setting up wireguard-tools (1.0.20200513-1~18.04) ...
wg-quick.target is a disabled or a static unit, not starting it.
Setting up wireguard (1.0.20200513-1~18.04) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
ProblemType: Package
DKMSBuildLog:
 DKMS make.log for wireguard-1.0.20200429 for kernel 5.3.0-53-generic (x86_64)
 Wed May 20 09:54:57 PDT 2020
 make: Entering directory '/usr/src/linux-headers-5.3.0-53-generic'
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/main.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/noise.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/device.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/peer.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/timers.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/queueing.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/receive.o
   CC [M]  /var/lib/dkms/wireguard/1.0.20200429/build/send.o
 In file included from <command-line>:0:0:
 /var/lib/dkms/wireguard/1.0.20200429/build/compat/compat.h:1024:20: error: redefinition of ‘skb_reset_redirect’
  static inline void skb_reset_redirect(struct sk_buff *skb)
 In file included from /var/lib/dkms/wireguard/1.0.20200429/build/compat/compat.h:870:0,
 ./include/linux/skbuff.h:4476:20: note: previous definition of ‘skb_reset_redirect’ was here
Originally, I installed it with ppa:wireguard/wireguard - is the install different now with this kernel?
FedKad
  • 13,420
Since, wireguard-dkms has been updated. The version 1.0.20200506-1~18.04 fix this problem. Now, it works with kernel 5.3.0-53, but it did not work anymore with the 5.3-051 version...
I had the same issue with the kernel version 4.4.0-184-generic. Reinstalling the wireguard-dkms package worked for me:
$ sudo apt-get --reinstall install wireguard-dkms
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 1 not upgraded.
Need to get 0 B/257 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 293587 files and directories currently installed.)
Preparing to unpack .../wireguard-dkms_1.0.20200611-0ppa1~16.04_all.deb ...
Deleting module version: 1.0.20200611 completely from the DKMS tree.
Done. Unpacking wireguard-dkms (1.0.20200611-0ppa1~16.04) over (1.0.20200611-0ppa1~16.04) ... Setting up wireguard-dkms (1.0.20200611-0ppa1~16.04) ... Loading new wireguard-1.0.20200611 DKMS files... Building only for 4.4.0-184-generic Building initial module for 4.4.0-184-generic Done.
wireguard: Running module version sanity check.
  • Original module
    • No original module exists within this kernel
  • Installation
    • Installing to /lib/modules/4.4.0-184-generic/kernel/net/
depmod....
DKMS: install completed. ~ $
Encountered the same issue with 5.3.0-1020-azure. For those who are unable to upgrade/downgrade their kernel (e.g. a hosted CI runner such as in GitHub Actions), installing some older version worked:
sudo apt install dkms
curl -L -o wireguard-tools.deb https://launchpad.net/~wireguard/+archive/ubuntu/wireguard/+build/19291633/+files/wireguard-tools_1.0.20200510-1~18.04_amd64.deb
curl -L -o wireguard-dkms.deb https://launchpad.net/~wireguard/+archive/ubuntu/wireguard/+build/19258545/+files/wireguard-dkms_1.0.20200429-2~18.04_all.deb
sudo dpkg -i wireguard-tools.deb
sudo dpkg -i wireguard-dkms.deb
sudo modprobe wireguard
dalazx
