I have searched all the answers to this issue but none have worked for me so far.
when I run: lspci -v | grep Network
i get this output:
03:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Subsystem: Bigfoot Networks, Inc. Device 1654
and when I run:
lshw -C network
my output is:
*-network
description: Ethernet interface
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 21
serial: b4:2e:99:a4:58:c9
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.63 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:18 ioport:3000(size=256) memory:58404000-58404fff memory:58400000-58403fff
*-network UNCLAIMED
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:58300000-58303fff
What I have tried:
sudo apt remove bcmwl-kernel-source && sudo apt install git dkms
git clone -b extended https://github.com/lwfinger/rtlwifi_new
sudo dkms add ./rtlwifi_new
sudo dkms install rtlwifi-new/0.6
then I rebooted the system
This didnt work so I tried this tutorial: https://www.youtube.com/watch?v=dokG4bCF4GQ&t=331s
Then I tried:
sudo apt-get install --reinstall bcmwl-kernel-source
and rebooted and still did not work.
I don't really know what else to try at this point, any help would be greatly appreciated.
