I am trying to make updates and installations and I keep getting errors like:
Err:1 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 cpp-8 amd64 8.3.0-6ubuntu1~18.04.1
What do I need to do to rectify these errors?
Here is the full attempt:
sudo apt install gcc-8
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
cpp-8 gcc-10-base gcc-9-base libasan5 libgcc-8-dev libgcc-s1 libubsan1
Suggested packages:
gcc-8-locales gcc-8-multilib gcc-8-doc libgcc1-dbg libgomp1-dbg libitm1-dbg libatomic1-dbg libasan5-dbg liblsan0-dbg libtsan0-dbg libubsan1-dbg
libmpx2-dbg libquadmath0-dbg
The following NEW packages will be installed:
cpp-8 gcc-10-base gcc-8 gcc-9-base libasan5 libgcc-8-dev libgcc-s1 libubsan1
0 upgraded, 8 newly installed, 0 to remove and 13 not upgraded.
Need to get 21.0 MB/21.6 MB of archives.
After this operation, 72.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
404 Not Found [IP: 91.189.88.142 80]
Err:2 http://security.ubuntu.com/ubuntu bionic-security/main amd64 libgcc-8-dev amd64 8.3.0-6ubuntu1~18.04.1
Err:3 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 gcc-8 amd64 8.3.0-6ubuntu1~18.04.1
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/universe/g/gcc-8/cpp-8_8.3.0-6ubuntu1~18.04.1_amd64.deb 404 Not Found [IP: 91.189.88.142 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-8/libgcc-8-dev_8.3.0-6ubuntu1~18.04.1_amd64.deb 404 Not Found [IP: 91.189.88.142 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/universe/g/gcc-8/gcc-8_8.3.0-6ubuntu1~18.04.1_amd64.deb 404 Not Found [IP: 91.189.88.142 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing
____________________________________________________________________________________
Also the scroll wheel does not work, but I don't know if it associated with this problem.
Thank you
