I recently replaced my old AMD Radeon video card with a GeForce GTX 650 in a PC with an AMD CPU.
The card seems to work fine, however, since the replacement, Xubuntu 18.04 gets seemingly random logouts every couple of hours. The screens turn black and a few seconds later, I find myself back at the greeter, having to log back in with all programs closed/crashed.
This did not happen once before and this also happened on a live system (Ubuntu MATE), so I assume the video card is definitely the culprit in the equation.
The error log apparently shows some problems with bamfdaemon at the timecode of the logout:
May 18 00:09:48 MACHINE bamfdaemon[2064]: bamfdaemon: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
May 18 00:09:48 MACHINE systemd[1611]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
May 18 00:09:48 MACHINE pulseaudio[1649]: X connection to :0.0 broken (explicit kill or server shutdown).
May 18 00:09:48 MACHINE at-spi-bus-launcher[1746]: X connection to :0 broken (explicit kill or server shutdown).
May 18 00:09:48 MACHINE systemd[1611]: bamfdaemon.service: Failed with result 'exit-code'.
May 18 00:09:48 MACHINE [2027]: xfce4-notifyd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
May 18 00:09:48 MACHINE systemd[1611]: xfce4-notifyd.service: Main process exited, code=exited, status=1/FAILURE
May 18 00:09:48 MACHINE systemd[1611]: xfce4-notifyd.service: Failed with result 'exit-code'.
May 18 00:09:48 MACHINE dbus-daemon[1673]: [session uid=1000 pid=1673] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.38' (uid=1000 pid=1941 comm="/usr/lib/tracker/tracker-miner-fs " label="unconfined")
May 18 00:09:48 MACHINE systemd[1611]: bamfdaemon.service: Service RestartSec=100ms expired, scheduling restart.
May 18 00:09:48 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 1.
May 18 00:09:48 MACHINE systemd[1611]: Stopped BAMF Application Matcher Framework.
May 18 00:09:48 MACHINE systemd[1611]: Starting BAMF Application Matcher Framework...
May 18 00:09:48 MACHINE systemd[1611]: Starting Tracker metadata database store and lookup manager...
May 18 00:09:48 MACHINE dbus-daemon[1673]: [session uid=1000 pid=1673] Successfully activated service 'org.freedesktop.Tracker1'
May 18 00:09:48 MACHINE systemd[1611]: Started Tracker metadata database store and lookup manager.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1541 (lightdm) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1652 (gnome-keyring-d) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1736 (ssh-agent) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1931 (applet.py) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1933 (zeitgeist-datah) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Killing process 1941 (tracker-miner-f) with signal SIGTERM.
May 18 00:09:48 MACHINE systemd[1]: Stopping Session c2 of user.
May 18 00:09:48 MACHINE bamfdaemon[26319]: Unable to init server: Could not connect: Connection refused
May 18 00:09:48 MACHINE bamfdaemon[26319]: cannot open display: :0
May 18 00:09:48 MACHINE systemd[1611]: Failed to start BAMF Application Matcher Framework.
May 18 00:09:48 MACHINE systemd[1611]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
May 18 00:09:48 MACHINE systemd[1611]: pulseaudio.service: Failed with result 'exit-code'.
May 18 00:09:48 MACHINE systemd[1]: session-c2.scope: Succeeded.
May 18 00:09:48 MACHINE systemd[1]: Stopped Session c2 of user.
May 18 00:09:48 MACHINE dbus-daemon[1040]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.15' (uid=0 pid=1057 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
May 18 00:09:48 MACHINE systemd[1]: Starting Network Manager Script Dispatcher Service...
May 18 00:09:48 MACHINE dbus-daemon[1040]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 18 00:09:48 MACHINE systemd[1]: Started Network Manager Script Dispatcher Service.
May 18 00:09:48 MACHINE systemd[1]: resolvconf-pull-resolved.service: Succeeded.
May 18 00:09:48 MACHINE systemd[1]: Started resolvconf-pull-resolved.service.
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Service RestartSec=100ms expired, scheduling restart.
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 2.
May 18 00:09:49 MACHINE systemd[1611]: pulseaudio.service: Service RestartSec=100ms expired, scheduling restart.
May 18 00:09:49 MACHINE systemd[1611]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
May 18 00:09:49 MACHINE systemd[1611]: Stopped Sound Service.
May 18 00:09:49 MACHINE systemd[1611]: Starting Sound Service...
May 18 00:09:49 MACHINE systemd[1611]: Stopped BAMF Application Matcher Framework.
May 18 00:09:49 MACHINE systemd[1611]: Starting BAMF Application Matcher Framework...
May 18 00:09:49 MACHINE systemd[1611]: Started Sound Service.
May 18 00:09:49 MACHINE bamfdaemon[26410]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
May 18 00:09:49 MACHINE bamfdaemon[26410]: cannot open display: :0
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Failed with result 'exit-code'.
May 18 00:09:49 MACHINE systemd[1611]: Failed to start BAMF Application Matcher Framework.
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 3.
May 18 00:09:49 MACHINE bamfdaemon[26439]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
May 18 00:09:49 MACHINE bamfdaemon[26439]: cannot open display: :0
May 18 00:09:49 MACHINE systemd[1]: Created slice User Slice of UID 112.
May 18 00:09:49 MACHINE systemd[1]: Starting User Runtime Directory /run/user/112...
May 18 00:09:49 MACHINE systemd[1]: Started User Runtime Directory /run/user/112.
May 18 00:09:49 MACHINE systemd[1]: Starting User Manager for UID 112...
May 18 00:09:49 MACHINE systemd[26450]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 18 00:09:49 MACHINE systemd[26450]: Reached target Timers.
May 18 00:09:49 MACHINE systemd[26450]: Listening on debconf communication socket.
May 18 00:09:49 MACHINE systemd[26450]: Listening on GnuPG cryptographic agent and passphrase cache.
May 18 00:09:49 MACHINE systemd[26450]: Reached target Paths.
May 18 00:09:49 MACHINE systemd[26450]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 18 00:09:49 MACHINE systemd[26450]: Listening on GnuPG network certificate management daemon.
May 18 00:09:49 MACHINE systemd[26450]: Listening on REST API socket for snapd user session agent.
May 18 00:09:49 MACHINE systemd[26450]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 18 00:09:49 MACHINE systemd[26450]: Starting D-Bus User Message Bus Socket.
May 18 00:09:49 MACHINE systemd[26450]: Listening on Sound System.
May 18 00:09:49 MACHINE systemd[26450]: Listening on D-Bus User Message Bus Socket.
May 18 00:09:49 MACHINE systemd[26450]: Reached target Sockets.
May 18 00:09:49 MACHINE systemd[26450]: Reached target Basic System.
May 18 00:09:49 MACHINE systemd[1]: Started User Manager for UID 112.
May 18 00:09:49 MACHINE systemd[26450]: Starting Sound Service...
May 18 00:09:49 MACHINE systemd[1]: Started Session c3 of user lightdm.
May 18 00:09:49 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 4.
May 18 00:09:50 MACHINE bamfdaemon[26474]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
May 18 00:09:50 MACHINE bamfdaemon[26474]: cannot open display: :0
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Main process exited, code=exited, status=1/FAILURE
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Failed with result 'exit-code'.
May 18 00:09:50 MACHINE systemd[1611]: Failed to start BAMF Application Matcher Framework.
May 18 00:09:50 MACHINE systemd[26450]: Started D-Bus User Message Bus.
May 18 00:09:50 MACHINE dbus-daemon[26477]: [session uid=112 pid=26477] AppArmor D-Bus mediation is enabled
May 18 00:09:50 MACHINE dbus-daemon[26477]: [session uid=112 pid=26477] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=112 pid=26473 comm="/usr/sbin/lightdm-gtk-greeter " label="unconfined")
May 18 00:09:50 MACHINE systemd[26450]: Starting Accessibility services bus...
May 18 00:09:50 MACHINE dbus-daemon[26477]: [session uid=112 pid=26477] Successfully activated service 'org.a11y.Bus'
May 18 00:09:50 MACHINE systemd[26450]: Started Accessibility services bus.
May 18 00:09:50 MACHINE dbus-daemon[26477]: [session uid=112 pid=26477] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=112 pid=26473 comm="/usr/sbin/lightdm-gtk-greeter " label="unconfined")
May 18 00:09:50 MACHINE systemd[26450]: Starting Virtual filesystem service...
May 18 00:09:50 MACHINE dbus-daemon[26477]: [session uid=112 pid=26477] Successfully activated service 'org.gtk.vfs.Daemon'
May 18 00:09:50 MACHINE systemd[26450]: Started Virtual filesystem service.
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Service RestartSec=100ms expired, scheduling restart.
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 5.
May 18 00:09:50 MACHINE systemd[1611]: Stopped BAMF Application Matcher Framework.
May 18 00:09:50 MACHINE systemd[1611]: Starting BAMF Application Matcher Framework...
May 18 00:09:50 MACHINE bamfdaemon[26496]: Invalid MIT-MAGIC-COOKIE-1 keyUnable to init server: Could not connect: Connection refused
May 18 00:09:50 MACHINE bamfdaemon[26496]: cannot open display: :0
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Scheduled restart job, restart counter is at 6.
May 18 00:09:50 MACHINE systemd[1611]: bamfdaemon.service: Start request repeated too quickly.
May 18 00:09:50 MACHINE rtkit-daemon[1525]: Successfully made thread 26466 of process 26466 owned by '112' high priority at nice level -11.
May 18 00:09:50 MACHINE rtkit-daemon[1525]: Supervising 1 threads of 1 processes of 2 users.
May 18 00:09:50 MACHINE rtkit-daemon[1525]: Successfully made thread 26511 of process 26466 owned by '112' RT at priority 5.
May 18 00:09:50 MACHINE rtkit-daemon[1525]: Supervising 2 threads of 1 processes of 2 users.
May 18 00:09:50 MACHINE systemd[26450]: Started Sound Service.
May 18 00:09:50 MACHINE systemd[26450]: Reached target Main User Target.
Is there anything that can be done about this or might this be an issue with the hardware itself? (Currently using Xubuntu 18.04 on Kernel 5.3)
Prototype700
  • 1,120
