I want to install ffmpeg but get the message below. How can I fix this ?
(base) h@cheemc52:~/opencv/build$ sudo apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
 ffmpeg : Depends: libavcodec56 (>= 10:2.6.9) but it is not going to be installed
          Depends: libavdevice56 (>= 10:2.6.9) but it is not going to be installed
          Depends: libavfilter5 (>= 10:2.6.9) but it is not going to be installed
          Depends: libavformat56 (>= 10:2.6.9) but it is not going to be installed
I am using Ubuntu 16.04
How do I know which is the correct solution ?
Solution 1
(base) h@cheemc52:~$ sudo aptitude install ffmpeg
The following NEW packages will be installed:
  ffmpeg libaacplus2{a} libass5{a} libavcodec56{ab} libavdevice56{a} libavfilter5{a} libavformat56{ab} libavresample2{a} libfaac0{a} libfdk-aac1{a}
  libpostproc53{a} libswresample1{a} libutvideo15{a} libvidstab1.0{a} libvo-aacenc0{a} libvo-amrwbenc0{a} libx264-146{a} libx265-51{a}
0 packages upgraded, 18 newly installed, 0 to remove and 74 not upgraded.
Need to get 8,543 kB of archives. After unpacking 23.1 MB will be used.
 libavformat56 : Depends: libgnutls-deb0-28 (>= 3.3.0) which is a virtual package and is not provided by any available package.
 libavcodec56 : Depends: libvpx1 (>= 1.3.0) which is a virtual package and is not provided by any available package.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     ffmpeg [Not Installed]
2)     libavcodec56 [Not Installed]
3)     libavdevice56 [Not Installed]
4)     libavfilter5 [Not Installed]
5)     libavformat56 [Not Installed]
Accept this solution? [Y/n/q/?]
Solution 2. All other solutions look similar to 2.
      Install the following packages:
1)      ffmpeg [7:2.8.15-0ubuntu0.16.04.1 (xenial-security, xenial-updates)]
2)      libavdevice-ffmpeg56 [7:2.8.15-0ubuntu0.16.04.1 (xenial-security, xenial-updates)]
3)      libavfilter-ffmpeg5 [7:2.8.15-0ubuntu0.16.04.1 (xenial-security, xenial-updates)]
4)      libbs2b0 [3.1.0+dfsg-2.2 (xenial)]
5)      libflite1 [2.0.0-release-1 (xenial)]
6)      libopenal-data [1:1.16.0-3 (now, xenial)]
7)      libopenal1 [1:1.16.0-3 (now, xenial)]
8)      libpostproc-ffmpeg53 [7:2.8.15-0ubuntu0.16.04.1 (xenial-security, xenial-updates)]
9)      libavcodec56 [Not Installed]
10)     libavdevice56 [Not Installed]
11)     libavfilter5 [Not Installed]
12)     libavformat56 [Not Installed]
Accept this solution? [Y/n/q/?] q
Kong
  • 1,329
