I used Rufus to put Lubuntu 20.04 on a USB pendrive with persistant storage. I can boot Lubuntu from USB and can save stuff persistently - great.
But the disk checkup runs for several minutes on every boot. Text says press Ctrl+C to cancel disk checkup but that does not cancel the already ongoing check of a very large file. So it still takes minutes.
This https://askubuntu.com/a/1232719/1083672 post says
Add
fsck.mode=skipto the Default menuentry for (UEFI boot mode).
Open /isolinux/txt.cfg as root and addfsck.mode=skipto the "Try Ubuntu without installing" menuentry, (for BIOS boot mode).
But I do not know where exactly in those files to add the string fsck.mode=skip and there is no example of that string in context in that answer
This is my grub.cfg . You can see where I have already tried to add the string. That did not work, the disk check still runs on boot.
if loadfont /boot/grub/font.pf2 ; then
set gfxmode=auto
insmod efi_gop
insmod efi_uga
insmod gfxterm
terminal_output gfxterm
fi
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
set timeout=30
menuentry "Start Lubuntu" {
fsck.mode=skip
set gfxpayload=keep
linux /casper/vmlinuz persistent file=/cdrom/preseed/lubuntu.seed quiet splash ---
initrd /casper/initrd
menuentry "Start Lubuntu (safe graphics)" {
fsck.mode=skip
set gfxpayload=keep
linux /casper/vmlinuz persistent file=/cdrom/preseed/lubuntu.seed quiet splash nomodeset ---
menuentry "OEM install (for manufacturers)" {
set gfxpayload=keep
linux /casper/vmlinuz persistent file=/cdrom/preseed/lubuntu.seed only-ubiquity quiet splash oem-config/enable=true ---
grub_platform
if [ "$grub_platform" = "efi" ]; then
menuentry 'Boot from next volume' {
exit
menuentry 'UEFI Firmware Settings' {
fwsetup
fi
This is my txt.cfg. I have no idea where to add the string here so have not tried anything yet.
default live
label live
menu label ^Start Lubuntu
kernel /casper/vmlinuz
append persistent file=/cdrom/preseed/lubuntu.seed initrd=/casper/initrd quiet splash ---
label live-nomodeset
menu label ^Start Lubuntu (safe graphics)
append persistent file=/cdrom/preseed/lubuntu.seed initrd=/casper/initrd quiet splash nomodeset ---
label memtest
menu label Test ^memory
kernel /install/mt86plus
label hd
menu label ^Boot from first hard disk
localboot 0x80
I tried to ask this in a comment to the above linked answer but do not have enough reputation to add comments yet. Thus this new question.
