I'm running Kubuntu 18.04 and I'm trying to use woeusb to create a boot memory stick for SuSE Leap. I've set the source to an ISO file for SuSE Leap and the target to /dev/sdb. I've unmounted /dev/sdb1, but I still get a puzzling error message:Source media is currently mounted, unmount the partition then try again. This is particularly mysterious because the source should be mounted.
How can I fix this?
Paul A.
  • 2,241
5 Answers5
Find the USB device you want to use, in my case it was /dev/sda1 with sudo lsblk.
Then simply unmount it with sudo umount /dev/sda1 and try again in WoeUSB
After running into the same issue just now, it is important to separate between the SOURCE media and the TARGET media. The target is the USB-Stick, the source is the windows iso. Turns out that after I downloaded the windows iso, ubuntu automatically mounted it.
I also ran after the USB-stick for a while, mounting and unmounting it, until I properly read the error and understood that I had to unmount THE ISO and not the usb stick to fix the issue... Two clicks later it was working.
BenSower
  • 510
Apparently it's necessary to explicitly unmount the source file. I've never before had to unmount an ordinary file, or at least a file that's not explicitly mounted to a device. I didn't even know that it's possible, but apparently it is.
Paul A.
  • 2,241
# https://github.com/WoeUSB/WoeUSB/releases
Release='https://github.com/WoeUSB/WoeUSB/releases/download/v5.2.4/woeusb-5.2.4.bash'
Woeusb = `basename $Release`
Iso="$windows_iso_address"
cd Downloads && \
mkdir Woeusb && \
cd Woeusb && \
wget "$Release" && \
sudo su
chmod +x "$Woeusb"
Windows = 'mnt/Windows'
mkdir "$Windows"
mount -o loop "$Iso" $Windows
Loopdevice = `df -h | grep $Windows`
File_system='NTFS'
Target_file_system="--target-filesystem $File-system"
Target="$Target_file_system"
bash $Woeusb --target-filesystem $Target \
             --device "$Loopdevice" \
             /dev/sd_
abc
  • 116
Just delete the line where it is terminating the program by modifying the /usr/bin/woeusb with vim by Searching for the error "Source media**" delete the line below it saying "exit 1". After that running the woeusb still show the error but installation will not be terminated.
