I recently installed Ubuntu 20.04 in 'Dual boot mode' alongside W10.
Internet connectivity is working as usual/expected within browser and terminal while browsing as well as downloading or upgrading packages, with exception to 'Ubuntu Software' store from the day of installation it is not working as expected!
Update: I am using a VPN connection in my machine, does it have any relation with this?
Any comments/suggestions please?
It always shows a loading scree(black screen with 3 dots) i guess,
Loading screen of Ubuntu Software store
After many hours also, it shows the same. If I tried to search for any particular app, at times only it shows the result most of the time it shows only the spinner icon
Searching for a particular software in store
Aravinth
  • 695
The issue was with the VPN connection I was testing that time.
As soon I stopped using it, no more issues with 'Software Center'.
Zanna
  • 72,312
Aravinth
  • 695
Ubuntu comes up with snap-store and it is stucks every time
You can install Gnome-software and it will fix the ubuntu software issue
sudo apt autoremove gnome-software && sudo apt install gnome-software
To remove the default Ubuntu Software
Goto Gnome-software>>Installed(tab)>>Remove Snap-store
I have the same issue. As a workaround, enter the System Monitor, find the gnome-software entry and end the process. Then open the store again.
Exactly the same issue, try reinstall the snap-store
snap remove snap-store && snap install snap-store
Then re-open the snap-store, the icon may change to a different one.
ibndias
