First time this ever happened with a Ubuntu release, I get a disc check each time I boot to a USB drive to Try Ubuntu 20.04.
Is because of the way the USB drive is formatted (NTSC) or the tool I used to create the bootable USB drive (Universal-USB-Installer)?
Or is there something I can change in Ubuntu 20.04 to stop this?
Removing Disk Check on Persistent USB's
The command line option fsck.mode=skip can be used to skip the disk check.
The line Checking disks: 0% complete will still come up but fsck will not be run, nor will boot time be increased.
mkusb After the Persistent USB drive is created, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the Persistent menuentry thus:
linux ($root)/casper/vmlinuz file=/cdrom/preseed/ubuntu.seed maybe-ubiquity fsck.mode=skip quiet splash persistent ---
  • Newer versions of mkusb already include this fix
  • If you also wish to remove the Try Ubuntu / Install Ubuntu screen delete "maybe-ubiquity".
UNetbootin After creating the boot drive, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the first menuentry for (UEFI boot mode).
  • Open syslinux.cfg as root and add fsck.mode=skip to the default menuentry for (BIOS boot mode).
Rufus After creating the boot drive, open /boot/grub/grub.cfg as root.
  • Add fsck.mode=skip to the Default menuentry for (UEFI boot mode).
  • Open /isolinux/txt.cfg as root and add fsck.mode=skip to the "Try Ubuntu without installing" menuentry, (for BIOS boot mode).
The Try Ubuntu / Install Ubuntu screen can be removed from BIOS boot by overwriting syslinux.cfg with:
default persistent
label persistent
  say Booting an Ubuntu Persistent session...
  kernel /casper/vmlinuz
  append  file=/cdrom/preseed/ubuntu.seed boot=casper persistent initrd=/casper/initrd quiet splash noprompt --
The Try Ubuntu / Install Ubuntu screen can be removed from Rufus UEFI boot by removing "maybe-ubiquity" from /boot/grub/grub.cfg.
Edit 20200524: The above workaround is no longer needed.
This bug was fixed in the package casper - 1.447, as announced in: https://bugs.launchpad.net/ubuntu/+source/casper/+bug/1875548
Run:
sudo apt-get update
sudo apt-get install -y casper
I am still testing this fix.
C.S.Cameron
  • 20,530
  • 78
  • 125
