I am unable to play videos in facebook or bbc iplayer. I am using firefox as my browser. In facebook,the video looks just the same after I press "play" as before. Its as though I have not pressed play at all. In bbc iplayer I get the message "this content doesn't seem to be working. Please try again later". I have tried several suggestions from this site including:
$ sudo apt-get install gnome-tweaks
$ sudo apt-get install libdvdnav4 libdvdread4 gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly libdvd-pk
$ sudo apt-get install ubuntu-restricted-extras
amongst others
Each time I get the following error message and have no idea what it means:
Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 4730 (apt-get)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
Please note, I am not an experienced linux user and my knowledge of coding and using the command terminal is very limited (the sudo commands I used above were copy pasted from similar problems posted on this website). I would therefore appreciate any explanations in clear, plain english, assuming no knowledge of coding or even how video enablement works in linux. Thank you
For video playback in the browser you only need to install the package ubuntu-restricted-extras. To do so open a terminal and type:
sudo apt install ubuntu-restricted-extras
Should that still fail with the error message you posted above, reboot and try again. Should the error persist, a previous update might have been interrupted and left the lock file in place, as Pilot6 commented above. To fix that:
  1. In a fresh terminal type sudo rm /var/lib/dpkg/lock-frontend
  2. Then make sure, all packages are installed correctly with sudo apt-get -f install
  3. Make sure the codecs are installed correctly with sudo apt install ubuntu-restricted-extras. When you are prompted to accept the EULA for the Microsoft fonts package, use Tab and Enter to agree.
After restarting your browser, video playback should work.
Béné
  • 1,026
I can now play videos thanks to the input of Bene and Pilot6. Solution was as follows: 1. $ sudo apt install ubuntu-restricted-extras On prompt/ message/ question by command terminal I typed in: 2. $ sudo dpkg --configure -a I accepted MS license by pressing tab, enter Package installed successfully
-1
I tried and failed to get videos to work. I install both clv and mpv and found that both worked. I chose to set music and video in Settings -> Default Applications to mpv. Whist I was fighting videos I may have install various codex which might just be essential to mpv.
