Persistent install to USB HD Partition
I have not encountered a tool for installing Live Ubuntu to an external data HDD/SSD without overwriting the data on it.
UNetbootin will do a frugal install to a HDD partition but only to C drive. The install is meant to be temporary and is used for installing Ubuntu.
It is possible to make a Full install of Ubuntu to Partitions on a data SSD or HDD using 'Something else" however most data disks have a msdos partition table which makes it necessary to create a new EFI partition table to boot in UEFI mode. this destroys the data on the drive.
It is easy to make a Live Ubuntu Install to a partition on a USB HDD/SSD as long as Non-Persistent BIOS mode boot is acceptable.
Boot a Live USB with target USB drive plugged in.
Start GParted and Resize/Move existing partition to create 20GB unallocated space.
Apply all operations.
Create a New ext4 partition in this space.
Apply all operations and exit GParted.
Open Terminal and type sudo -H nautilus.
Open the Ubuntu ISO file using Archive Manager.
Extract the ISO to the new ext4 partition.
In Terminal run:
sudo mount /dev/sdx2 /mnt
sudo grub-install --boot-directory=/mnt/boot /dev/sdx
Where sdx2 is the New ext4 partition and sdx is the target USB drive.
Edit Boot/grub/grub.cfg adding:
set root=(hd0,2)
after the "Try Ubuntu ..." line.
If you want persistence or to multiboot ISO files or ability to boot in either BIOS or UEFI, or do a Full install, etc. let me know and I will edit this answer
