I installed tlp but I am wondering how would I disable tlp. I read the docs and it said to disable it you have to set TLP_ENABLE=0 but how would I do that.
Is there a different way of disabling it from the terminal.
Geralt
  • 169
Your were on the right track. You actually have to change the config file as explained in the documentation.
You must do this as root or with sudo:
sudo nano /etc/tlp.conf
If you have an older TLP version < 1.3 installed, it's a different file:
sudo nano /etc/default/tlp
To determine your version, use the command
tlp-stat -s
and check the first line of the output for the version number.
Once in the editor change the line #26 from
#TLP_ENABLE=1
to
TLP_ENABLE=0
Remember to remove the leading #. Once finished leave nano saving the file with
Ctrl-X Y <Enter>
and reboot.
linrunner
  • 1,525
