I Solved it
The solution is in my own answer (se my next post). This post only describes my original problem and what I've tried.
The may be some pointers in it for you though... or not.
I Solved it ends
First of all i'm pretty new to linux. Here's the deal. My old computer mainboard has failed me. That no problem I just bye a new one. However I had been stupid enough to use Intels RST, wich was onboard the old mainboard but not the new one. Now the question is if it is posible to recover the RST raid, without the Intel RST boot expantion? It dosn't look like the disks has automagicaly been assembled to one volume. It seems to my that it is posible, but when it comes to raid and disk/partion mangement, my knowledge pretty much stops at gparted.
So far I've found that blkid for both disks gives (and only gives):
/dev/sdb: TYPE="isw_raid_member"
/dev/sda: TYPE="isw_raid_member"
That looks allright.
mdadm -E gives me:
mdadm -E /dev/sdb /dev/sda
mdadm: /dev/sdb is not attached to Intel(R) RAID controller.
/dev/sdb:
Magic : Intel Raid ISM Cfg Sig.
Version : 1.0.00
Orig Family : 3ad31c33
Family : 3ad31c33
Generation : 000006b7
Attributes : All supported
UUID : f508b5ef:ce7013f7:fcfe0803:ba06d053
Checksum : 0798e757 correct
MPB Sectors : 1
Disks : 2
RAID Devices : 1
Disk00 Serial : 6VYCWHXL
State : active
Usable Size : 488391680 (232.88 GiB 250.06 GB)
[Volume0]:
UUID : 529ecb47:39f4bc8b:0f05dbe3:960195fd
RAID Level : 0
Members : 2
Slots : [UU]
Failed disk : none
This Slot : 0
Sector Size : 512
Array Size : 976783360 (465.77 GiB 500.11 GB)
Per Dev Size : 488391944 (232.88 GiB 250.06 GB)
Sector Offset : 0
Num Stripes : 1907780
Chunk Size : 128 KiB
Reserved : 0
Migrate State : idle
Map State : normal
Dirty State : clean
RWH Policy : off
Disk01 Serial : W2A50R0P
State : active
mdadm: /dev/sda is not attached to Intel(R) RAID controller.
/dev/sda:
Version : 1.0.00
Family : 3ad31c33
MPB Sectors : 1
Disks : 2
RAID Devices : 1
State : active
[Volume0]:
RAID Level : 0
Members : 2
Slots : [UU]
Failed disk : none
This Slot : 1
Sector Size : 512
Sector Offset : 0
Reserved : 0
Map State : normal
Dirty State : clean
RWH Policy : off
State : active
So is it posible to safly reassmble theese two disks into a single volume? eg mdadmin --assemble
I'm in doubt about the workings of mdadm. So this is a good learning experience for me.
lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 19.10
Release: 19.10
Codename: eoan
uname -a
Linux HPx64 5.3.0-51-generic #44-Ubuntu SMP Wed Apr 22 21:09:44 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Note that it was named HPx64 because i've reused the Ubuntu installation and that is a xUbuntu
--- Update 2020-05-15 ---
Found out that seting the IMSM_NO_PLATFORM=1 env.var. has two affects (so far). 1) Removes the "mdadm: /dev/sdb is not attached to Intel(R) RAID controller." warning output from:
mdadm -E /dev/sdb
2) Removes the "mdadm: /dev/sdb is not attached to Intel(R) RAID controller." output from:
mdadm --assemble /dev/md0 /dev/sdb /dev/sda
Status now after assemble is that md0 devices is created in dev:
cat /proc/mdstat
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md0 : inactive sdb[1](S) sda[0](S)
5488 blocks super external:imsm
unused devices: <none>
And
mdadm -E /dev/md0
/dev/md0:
Version : 1.0.00
Family : 3ad31c33
MPB Sectors : 1
Disks : 2
RAID Devices : 1
State : active
[Volume0]:
RAID Level : 0
Members : 2
Slots : [UU]
Failed disk : none
This Slot : 0
Sector Size : 512
Sector Offset : 0
Reserved : 0
Map State : normal
Dirty State : clean
RWH Policy : off
State : active
And
mdadm --query --detail /dev/md0
/dev/md0:
Version : imsm
Raid Level : container
Total Devices : 2
Working Devices : 2
Member Arrays :
Number Major Minor RaidDevice
- 8 0 - /dev/sda
- 8 16 - /dev/sdb
So it's some of the way but something is still wrong. It seems that the volume isn't exposed to the system and the examine of md0 is simular to sdb. Any ideas and thoughts are welcome.
