I tried to create a custom mimetype (text/graphml+xml) by creating the file ~/.local/share/mime/packages/graphml+xml-mime.xml with this content:
<?xml version="1.0" encoding="UTF-8"?>
 <mime-info xmlns='http://www.freedesktop.org/standards/shared-mime-info'>
   <mime-type type="text/x-graphml+xml">
   <comment>GraphML file</comment>
   <acronym>GraphML</acronym>
   <expanded-acronym>Graph Modelling Language</expanded-acronym>
   <sub-class-of type="text/xml"/>
   <glob pattern="*.graphml"/>
  </mime-type>
 </mime-info>
And installed an appropriate icon with:
xdg-icon-resource-resourse install --context mimetype --novendor --size ${size} --mode user text-x-graphml+xml.png
Then updated the database with
update-mime-database ~/.local/share/mime
But the icon for a my.graphml file is not displayed in nautilus (it's a debian minimal gnome system).
The icons in ~/.local/share/icon/hicolor/${size}x${size}/mimetype/text-x-graphml+xml.png does exist.
gio info my.graphml says:
standard::icon: text-x-graphml+xml, text-x-generic, text-x-graphml+xml-symbolic, text-x-generic-symbolic
standard::content-type: text/x-graphml+xml
standard::fast-content-type: text/x-graphml+xml
I can double click it and the file is opened with yed (as I want - did create the ~/.local/share/applicatons/yed.desktop file and the application does show in the applications pannel with the appropriate icon).
But no icon! :-(
EDIT:
It's a debian testing system, installed with debootstrap and grown from there (trying to keep it minimal). I'm afraid this might also mean some packages might be missing...
Nathaniel M. Beaver is right - this is the same question he already answered in Assign an icon to a custom mimetype - Unix & Linux
The fix
Use this XML file instead:
   <mime-type type="application/x-graphml+xml">
   <icon name="x-graphml+xml"/>
  </mime-type>
 </mime-info>
and make sure you run xdg-icon-resource with
--context mimetypes
not
--context mimetype
otherwise they'll go in the wrong folder.
For example, if the icon is 48x48, the installation commands will look like this:
xdg-mime install --mode user graphml+xml-mime.xml
xdg-icon-resource install --context mimetypes --size 48 text-x-graphml+xml.png x-graphml+xml
update-icon-caches ~/.local/share/icons
Attempt at an explanation
This is a strange one. It appears the difficulty is that when the mimetype is
text/x-graphml+xml
instead of
it defaults to the generic text icon. This seems to depend on the file manager and desktop, though.
Kulfy
  • 18,154
