I bought a new laptop (Dell 3493) and moved my installation disk from my old one. I had in it the 18.04 LTS and after some troubles I decided to update to 20.04 LTS. I got everything to work except those 3 programs, which never start.
This is what I got with Shotcut:
No appenders associated with category qt.network.ssl [Warning] <> QSslSocket: cannot call unresolved function SSLv23_client_method No appenders associated with category qt.network.ssl [Warning] <> QSslSocket: cannot call unresolved function SSL_library_init Segmentation fault (core dumped)
This is what Kdenlive shows:
MLT ERROR: "[consumer sdl2_audio ] Failed to initialize SDL: Could not setup connection to PulseAudio"
org.kde.knotifications: Audio notification requested, but sound file from notifyrc file was not found, aborting audio notification Segmentation fault (core dumped)
And this is what I got from Blender:
Writing: /tmp/blender.crash.txt Segmentation fault (core dumped)
About Kdenlive, when I use the snap version on the official ppa got as well a Segmentation fault (core dumped). I couldn't find proper answers in the web (by the way, I've tried to reinstall an reboot a couple of times those apps).
mekax
For kdenlive had the same problem. I resolved it using the appimage from the official web site. Maybe you can do the same with blender and shortcut…
  • remove kdenlive
  • download appimage from the official website: wget https://files.kde.org/kdenlive/release/kdenlive-20.04.1b-x86_64.appimage -O ~/Downloads
  • install appimage library: sudo apt install libappimage0
  • add execution bit to the .appimage file: chmod +x ~/Downloads/kdenlive-20.04.1b-x86_64.appimage
  • execute the file ~/Downloads/kdenlive-20.04.1b-x86_64.appimage
CIMIA
The problem seems not limited to three programs mentioned in the question. According to this answer it is a bug in mesa drivers. Adding following line to .profile seems let the programs start (I can confirm it for Blender and Kdenlive)
MESA_LOADER_DRIVER_OVERRIDE=i965
However it is not a proper fix and we have to wait for the problem to be solved in drivers.
Hamon
  • 116
