NOTE: This answer attempts to answer the OP's question as well as the similar problem Erel is having which prompted the bounty.
Firstly, it should be pointed out that unless you have compiled your PHP with the ./configure flag --without-pear or you are running you are running PHP 4.2.* or earlier, you should already have a base installation of PEAR, and it should already contain everything needed to install PEAR packages.
The rest of my answer assumes PEAR was either not installed by default or was misconfigured. Either way, here is how I installed it manually.
Note: If you have multiple versions of PHP installed locally and are not using a VM or Docker, remember to first switch PHP versions. For example, I normally use PHP 7.4 but wanted to reproduce using 5.6, so I had to run the following.
sudo a2dismod php7.4
sudo a2enmod php5.6
sudo service apache2 restart
sudo update-alternatives --set php /usr/bin/php5.6
sudo update-alternatives --set phar /usr/bin/phar5.6
sudo update-alternatives --set phar.phar /usr/bin/phar.phar5.6
If you have php5.6-dev installed as well
sudo update-alternatives --set phpize /usr/bin/phpize5.6
sudo update-alternatives --set php-config /usr/bin/php-config5.6
Now check your PHP version php -v and it should output something like this.
PHP 5.6.40-57+ubuntu20.04.1+deb.sury.org+1 (cli)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies with Zend
OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
The recommended method of installing or modifying PEAR is with wget, not aptitude. So you also need to have wget installed.
sudo apt install wget
Now acquire go-pear.phar and ensure the command resolves and the response is saved to go-pear.phar locally.
wget http://pear.php.net/go-pear.phar
And then run the file with PHP.
php go-pear.phar
PHP will suggest the defaults for your new PEAR installation, which should be perfectly fine for most use cases.
Below is a suggested file layout for your new PEAR installation. To
change individual locations, type the number in front of the
directory. Type 'all' to change all of them or simply press Enter to
accept these locations.
- Installation base ($prefix) : /home/test/pear
- Temporary directory for processing : /tmp/pear/install
- Temporary directory for downloads : /tmp/pear/install
- Binaries directory : /home/test/pear/bin
- PHP code directory ($php_dir) : /home/test/pear/share/pear
- Documentation directory : /home/test/pear/docs
- Data directory : /home/test/pear/data
- User-modifiable config files directory : /home/test/pear/cfg
- Public Web Files directory : /home/test/pear/www
- System manual pages directory : /home/test/pear/man
- Tests directory : /home/test/pear/tests
- Name of configuration file : /home/test/.pearrc
1-12, 'all' or Enter to continue:
Hit the ENTER key.
Note: If you get an error XML extension not found, first install the XML module (be sure the version number if not using 5.6) and try again.
sudo apt-get install php-xml php5.6-xml
Here is the output I observed.
Beginning install...
Configuration written to /home/test/.pearrc...
Initialized registry...
Preparing to install...
installing phar:///home/test/go-pear.phar/PEAR/go-pear-tarballs/Archive_Tar-1.4.14.tar...
installing phar:///home/test/go-pear.phar/PEAR/go-pear-tarballs/Console_Getopt-1.4.3.tar...
installing phar:///home/test/go-pear.phar/PEAR/go-pear-tarballs/PEAR-1.10.13.tar...
installing phar:///home/test/go-pear.phar/PEAR/go-pear-tarballs/Structures_Graph-1.1.1.tar...
installing phar:///home/test/go-pear.phar/PEAR/go-pear-tarballs/XML_Util-1.4.5.tar...
install ok: channel://pear.php.net/Archive_Tar-1.4.14
install ok: channel://pear.php.net/Console_Getopt-1.4.3
install ok: channel://pear.php.net/Structures_Graph-1.1.1
install ok: channel://pear.php.net/XML_Util-1.4.5
install ok: channel://pear.php.net/PEAR-1.10.13
PEAR: Optional feature webinstaller available (PEAR's web-based installer)
PEAR: Optional feature gtkinstaller available (PEAR's PHP-GTK-based installer)
PEAR: Optional feature gtk2installer available (PEAR's PHP-GTK2-based installer)
PEAR: To install optional features use "pear install pear/PEAR#featurename"
WARNING! The include_path defined in the currently used php.ini does not contain the PEAR PHP directory you just specified:
</home/test/pear/share/pear>
If the specified directory is also not in the include_path used by your scripts, you will have problems getting any PEAR packages working.
Would you like to alter php.ini </etc/php/5.6/cli/php.ini>? [Y/n] : y
WARNING: Cannot write to /etc/php/5.6/cli/php.ini, but php.ini was successfully created at </home/test/pear/php.ini-gopear>. Please replace the file </etc/php/5.6/cli/php.ini> with </home/test/pear/php.ini-gopear> or modify your php.ini by adding:
include_path=".:/home/test/pear/share/pear"
Current include path : .:/usr/share/php
Configured directory : /home/test/pear/share/pear
Currently used php.ini (guess) : /etc/php/5.6/cli/php.ini
Press Enter to continue:
** WARNING! Old version found at /usr/bin/pear, please remove it or be sure
to use the new /home/test/pear/bin/pear command
The 'pear' command is now at your service at /home/test/pear/bin/pear
Because of the warning in the output, I opted to manually edit my php.ini.
sudo nano /etc/php/5.6/cli/php.ini
Scroll to the Paths and Directories section.
; Paths and Directories ;
; UNIX: "/path1:/path2"
;include_path = ".:/usr/share/php"
; Windows: "\path1;\path2"
;include_path = ".;c:\php\includes"
; PHP's default setting for include_path is ".;/path/to/php/pear"
; http://php.net/include-path
I uncommented the line ;include_path = ".:/usr/share/php" and replaced it with include_path=".:/home/test/pear/share/pear" and restarted Apache.
To verify PEAR is working, simply type pear on the command line. My final output is shown below.
test@REDQUEEN1:~$ pear
Commands:
build Build an Extension From C Source
bundle Unpacks a Pecl Package
channel-add Add a Channel
channel-alias Specify an alias to a channel name
channel-delete Remove a Channel From the List
channel-discover Initialize a Channel from its server
channel-info Retrieve Information on a Channel
channel-login Connects and authenticates to remote channel server
channel-logout Logs out from the remote channel server
channel-update Update an Existing Channel
clear-cache Clear Web Services Cache
config-create Create a Default configuration file
config-get Show One Setting
config-help Show Information About Setting
config-set Change Setting
config-show Show All Settings
convert Convert a package.xml 1.0 to package.xml 2.0 format
cvsdiff Run a "cvs diff" for all files in a package
cvstag Set CVS Release Tag
download Download Package
download-all Downloads each available package from the default channel
info Display information about a package
install Install Package
list List Installed Packages In The Default Channel
list-all List All Packages
list-channels List Available Channels
list-files List Files In Installed Package
list-upgrades List Available Upgrades
login Connects and authenticates to remote server [Deprecated in favor of channel-login]
logout Logs out from the remote server [Deprecated in favor of channel-logout]
makerpm Builds an RPM spec file from a PEAR package
package Build Package
package-dependencies Show package dependencies
package-validate Validate Package Consistency
pickle Build PECL Package
remote-info Information About Remote Packages
remote-list List Remote Packages
run-scripts Run Post-Install Scripts bundled with a package
run-tests Run Regression Tests
search Search remote package database
shell-test Shell Script Test
sign Sign a package distribution file
svntag Set SVN Release Tag
uninstall Un-install Package
update-channels Update the Channel List
upgrade Upgrade Package
upgrade-all Upgrade All Packages [Deprecated in favor of calling upgrade with no parameters]
Usage: pear [options] command [command-options] <parameters>
Type "pear help options" to list all options.
Type "pear help shortcuts" to list all command shortcuts.
Type "pear help version" or "pear version" to list version information.
Type "pear help <command>" to get the help for the specified command.
References:
