first of all thanks for your help!I have a weird situation here. I am running several VMs on a ESXi white box and one of the Linux VMs started acting weirdly.
I cannot perform apt-get upgrade or any other install (docker container) as the installs always fail with "Hash Sum mismatch". If I try running simple "wget https://mirror.umd.edu/ubuntu-iso/20.04/ubuntu-20.04-live-server-amd64.iso" as a test the speeds is around ~30-1500KB/s. While for the apt-get upgrade the speed is relatively normal, but fails as well. LAN speed is fine and is around 100MB/s.
If I try doing the same thing in a different VM, using 18.04LTS as well, behaviour is completely normal. Installs go through, speed is around 25MB/s which is in line with the connection I have.
I have not performed any hardware changes or configuration changes in the ESXI or the Ubuntu VM. Doing the "tests" above tells me this is a software issue and not a hardware one.
I've tried googling around and performed with no results. sudo rm -rf /var/lib/apt/lists/* sudo apt-get update sudo apt-get upgrade
panda@box:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  linux-firmware
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 75.1 MB of archives.
After this operation, 10.2 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-firmware all 1.173.18 [75.1 MB]
Err:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-firmware all 1.173.18
  Hash Sum mismatch
  Hashes of expected file:
   - SHA256:099bbc0f958db43fad328f9f09065e448a85dcdb126691c2dab040213af13e41
   - SHA1:31b98ad6e6d2ca49e1a5297d9913d0be41f2a965 [weak]
   - MD5Sum:60b003009991844b6f8cd73bc185989a [weak]
   - Filesize:75056824 [weak]
  Hashes of received file:
   - SHA256:0c404bce54ff28a87300f0ba933726ea7bc7008cc1edd4b8586f2f93a5bab2e8
   - SHA1:d5d35d984788d6e25b10abdaf09f33614dd1fa72 [weak]
   - MD5Sum:94495275aa23904b065cb37185d35b8e [weak]
  Last modification reported: Wed, 06 May 2020 15:18:25 +0000
Fetched 75.1 MB in 6s (12.6 MB/s)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.173.18_all.deb  Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
